[petsc-users] About DIVERGED_ITS
    w_ang_temp
    w_ang_temp at 163.com
    Sat Jul  7 11:15:25 CDT 2012
    Maybe it is a problem of mathematical concept. I compare the result with the true result which is
computed and validated by other tools. I think it is right if I get the same result.
在 2012-07-08 00:03:21,"Matthew Knepley" <knepley at gmail.com> 写道:
On Sat, Jul 7, 2012 at 10:00 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
Hello,
    I am a little puzzled that I get the right result while the converged reason says that 'Linear solve did not
converge due to DIVERGED_ITS iterations 10000'. This infomation means that the iterations reach the maximum
iterations. But the result is right now. So why says 'did not converge'? Can I think that the result is right and
can be used?
Obviously, your definition of "right" is not the same as the convergence tolerances you are using.
    Matt
    Thanks.
                                            Jim
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120708/f44e555e/attachment.html>
