[petsc-users] About DIVERGED_ITS
Sat Jul 7 11:03:21 CDT 2012
On Sat, Jul 7, 2012 at 10:00 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
> Hello,
>     I am a little puzzled that I get the right result while the converged
> reason says that 'Linear solve did not
> converge due to DIVERGED_ITS iterations 10000'. This infomation means that
> the iterations reach the maximum
> iterations. But the result is right now. So why says 'did not converge'?
> Can I think that the result is right and
> can be used?
Obviously, your definition of "right" is not the same as the convergence
tolerances you are using.
    Matt
>     Thanks.
>                                             Jim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120707/59b7aab1/attachment.html>
