[petsc-users] error compiling on MPI_Win
Jed Brown
jedbrown at mcs.anl.gov
Thu Jul 5 16:52:13 CDT 2012
On Thu, Jul 5, 2012 at 1:42 PM, hbui <hgbk2008 at gmail.com> wrote:
> Thanks for reply, the compiler command is:
> g++ -I/opt/petsc/petsc-dev/include -I/opt/petsc/petsc-dev/include/mpiuni
> -O3 -Wall -c -fmessage-length=0 -MMD -MP -MF"PETScSolver.d"
> -MT"PETScSolver.d" -o "PETScSolver.o" "../PETScSolver.cpp"
You are using the wrong compiler and including the mpiuni directory.
Compilers:
C Compiler: mpicc -fPIC -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -O
Fortran Compiler: mpif90 -fPIC -Wall -Wno-unused-variable
-Wno-unused-dummy-argument -O
Linkers:
Shared linker: mpicc -shared -fPIC -Wall -Wwrite-strings
Dynamic linker: mpicc -shared -fPIC -Wall -Wwrite-strings
MPI:
Includes: -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
Use a PETSc makefile or get the compiler and include paths from PETSc. This
mpicc appears to be a valid MPI-2 implementation so everything should work
with it.
> I have used the latest BuildSystem (hg pull -u) before compiling. I
> already sent the configure.log to petsc-maint at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120705/17099f0f/attachment.html>
