[petsc-users] Adapting MatMult and PCMG functions in matrix-free method.
Jed Brown
jedbrown at mcs.anl.gov
Thu Jul 5 16:41:11 CDT 2012
On Thu, Jul 5, 2012 at 10:38 AM, domenico lahaye
<domenico_lahaye at yahoo.com>wrote:
> Hi Jed,
> Thank you for your reply. The Algorithm II is described in the paper
> @ARTICLE{yoginabben1,
> author = {Erlangga, Y.A. and R. Nabben},
> title = {On a multilevel {K}rylov Method for the {H}elmholtz Equation
> preconditioned
> by Shifted {L}aplacian},
> journal = {Electronic Transaction on Num. Analysis (ETNA)},
> year = {2008},
> volume = {31},
> pages = {403--424},
As I interpret this method, you have custom interpolation operators and a
Krylov smoother that is itself a multigrid cycle with the shifted operator.
In PETSc parlance, you have two matrices, the operator A and the
preconditioning matrix M. Here M would be the shifted matrix and smoothing
would involve MG cycles with coarsened approximations of M. I would start
with the PCMG interface, use a Krylov method as the smoother, and perhaps
use PCComposite or PCShell as the preconditioner for the Krylov smoother.
Eventually the preconditioner for your Krylov smoother will call the
"other" MG cycle (a standard method applied to M).
Note that this method involves an enormous number of synchronization points
as well as high operator complexity, so you may find the cost to be quite
high even though the iteration count is not bad.
> Kind wishes, Domenico.
> *From:* Jed Brown <jedbrown at mcs.anl.gov>
> *To:* domenico lahaye <domenico_lahaye at yahoo.com>; PETSc users list <
> petsc-users at mcs.anl.gov>
> *Cc:* Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>
> *Sent:* Thursday, July 5, 2012 7:47 PM
> *Subject:* Re: [petsc-users] Adapting MatMult and PCMG functions in
> matrix-free method.
> Can you reference a paper or some notes on the algorithm?
> On Thu, Jul 5, 2012 at 8:40 AM, domenico lahaye <domenico_lahaye at yahoo.com
> > wrote:
> Dear PETSc developers,
> Thank you for your support to Abdul.
> We are in the process of developing a multilevel
> Krylov solver for the Helmholtz equation. Abdul
> has implemented Algorithm I for this purpose.
> We next would like to implement Algorithm II.
> Algorithm || amounts to replacing every occurrence
> of the system matrix $A$ in Algorithm I by
> $M^{-1} A$. This replacement should occur on all
> levels. We thought of two ways to realize this
> replacement.
> 1) We thought of adopting a matrix-free approach,
> and to plug in the operation with $M^{-1}$ there.
> This would require a ksp context inside MatMult.
> We wonder whether this a approach is feasible to
> take.
> 2) The other approach would by to implement a
> customized pcmg preconditioner that we can adapt
> to our needs. This could be a more elegant approach,
> at the cost of doing more work. Is the assumption
> that the second approach is more elegant correct
> and would you be able to give advice on how to tackle
> this approach?
> ----- Forwarded Message -----
> *From:* Matthew Knepley <knepley at gmail.com>
> *To:* Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk>; PETSc users list <
> *Sent:* Thursday, 5 July 2012, 15:45
> matrix-free method.
> On Thu, Jul 5, 2012 at 7:34 AM, Abdul Hanan Sheikh <hanangul12 at yahoo.co.uk
> > wrote:
> Dear developers and users,
> Summer greetings.
> We have few question listen below:
> 1.
> The first question is about adapting " MatMult " function in matrix-free
> method.
> We intend to incorporate a KSP context inside "MatMult" . The immediate
> question is how to
> provide more than one matrices as input.
> You provide extra data through the context for the MATSHELL
> Is this idea of incorporating a KSP context inside "MatMult" function
> workable ? Does it make any confrontation
> with philosophy of development of Petsc. ?
> I am not sure you want this. Do you think PCKSP can do what you want?
> There is not enough information here to help us answer.
> 2.
> An other advance level feedback is needed.
> Re-implementing PCMG function { mg.c } will lead any violation of
> philosophy of Petsc-development ??
> Again, there is not enough information. Can you do what you want by just
> replacing the monitors?
> Thanks,
> Matt
> 3.
> Which one of the above both is more elegant and feasible to work on ?
> Thanking in anticipation,
> Abdul
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120705/cf8ccd10/attachment-0001.html>
