[petsc-users] -mat_superlu_lwork
Hong Zhang hzhang at mcs.anl.gov
Tue Jul 3 11:45:14 CDT 2012
Gianluca:
Checking Superlu source code SuperLU_4.3/SRC/dgssvx.c,
this input format is required by superlu.
Hong
Hong,
> thanks for your answer. I do not know if my problem request 64 bit support.
> My understanding is that I can preallocate the working array for
> superlu with the PETSc database options -mat_superlu_lwork. Following
> PETSc manual, this has to be specified in bytes.
> From my point of view, the problem is that I cannot pass to PETSc an
> integer greater than 2.147.483.647 (that is, LONG_MAX), thus I am
> limited to allocating roughly 2 GB of memory. If my factored matrix is
> bigger, I have to rely on the mallocs/copy.
> Let me know if it is not clear yet.
> Gianlu
> On 3 July 2012 15:53, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> > Gianluca:
> > Do you mean 64-bit support for superlu?
> > I do not understand your request, thus forward your request to superlu
> > developer.
> > Hong
> >> Dear all,
> >> I am trying to use superlu as solver for a large, sparse matrix, and I
> >> would like to use -mat_superlu_lwork to speed up the computation. The
> >> problem I encounter is that my lwork size I would need is greated than
> >> the maximum value for an object of type long int and is not correctly
> >> read by the code.
> >> Is there a workaround to that? Does using another solver (mumps
> >> maybe?) solve this problem and, if so, which option should I use?
> >> Thanks in advance
> >> Gianluca
> >> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
> >> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
> >> l'Anonymat" -- Non omnibus, sed mihi et tibi
> >> Amedeo Modigliani
> Amedeo Modigliani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120703/134497e6/attachment.html>
