[petsc-users] understanding MatNullSpaceTest
Klaij, Christiaan
C.Klaij at marin.nl
Tue Jul 3 07:18:57 CDT 2012
I'm trying to understand the use of null spaces. Whatever I do, it
always seem to pass the null space test. Could you please tell me
what's wrong with this example (c++, petsc-3.3-p1):
$ cat nullsp.cc
// test null space check
#include <petscksp.h>
int main(int argc, char **argv) {
PetscErrorCode ierr;
PetscInt row,start,end;
PetscScalar val[1];
PetscReal norm;
Mat A;
Vec x,y;
MatNullSpace nullsp;
PetscBool isNull;
ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL); CHKERRQ(ierr);
// diagonal matrix
ierr = MatCreate(PETSC_COMM_WORLD,&A); CHKERRQ(ierr);
ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,24,24); CHKERRQ(ierr);
ierr = MatSetType(A,MATMPIAIJ); CHKERRQ(ierr);
ierr = MatMPIAIJSetPreallocation(A,1,PETSC_NULL,1,PETSC_NULL); CHKERRQ(ierr);
ierr = MatGetOwnershipRange(A,&start,&end); CHKERRQ(ierr);
for (row=start; row<end; row++) {
val[0] = 1.0;
ierr = MatSetValues(A,1,&row,1,&row,val,INSERT_VALUES); CHKERRQ(ierr);
ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
// random vector
ierr = VecCreate(PETSC_COMM_WORLD,&x); CHKERRQ(ierr);
ierr = VecSetSizes(x,PETSC_DECIDE,24); CHKERRQ(ierr);
ierr = VecSetType(x,VECMPI); CHKERRQ(ierr);
ierr = VecSetRandom(x,PETSC_NULL); CHKERRQ(ierr);
// null space
ierr = MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_FALSE,1,&x,&nullsp); CHKERRQ(ierr);
ierr = MatNullSpaceTest(nullsp,A,&isNull); CHKERRQ(ierr);
if (isNull==PETSC_TRUE) {
ierr = PetscPrintf(PETSC_COMM_WORLD,"null space check passed\n");
else {
ierr = PetscPrintf(PETSC_COMM_WORLD,"null space check failed\n");
// check null space
ierr = VecDuplicate(x,&y); CHKERRQ(ierr);
ierr = MatMult(A,x,y); CHKERRQ(ierr);
ierr = VecNorm(y,NORM_2,&norm); CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD,"|Ax| = %G\n",norm); CHKERRQ(ierr);
ierr = PetscFinalize(); CHKERRQ(ierr);
return 0;
$ mpiexec -n 2 ./nullsp -log_summary
|Ax| = 2.51613
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./nullsp on a linux_64b named lin0133 with 2 processors, by cklaij Tue Jul 3 14:03:34 2012
Using Petsc Release Version 3.3.0, Patch 1, Fri Jun 15 09:30:49 CDT 2012
Max Max/Min Avg Total
Time (sec): 4.794e-03 1.00000 4.794e-03
Objects: 1.400e+01 1.00000 1.400e+01
Flops: 7.200e+01 1.00000 7.200e+01 1.440e+02
Flops/sec: 1.502e+04 1.00000 1.502e+04 3.004e+04
Memory: 5.936e+04 1.00000 1.187e+05
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 4.100e+01 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 4.7846e-03 99.8% 1.4400e+02 100.0% 0.000e+00 0.0% 0.000e+00 0.0% 4.000e+01 97.6%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %f - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
# WARNING!!! #
# This code was compiled with a debugging option, #
# To get timing results run ./configure #
# using --with-debugging=no, the performance will #
# be generally two or three times faster. #
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult 1 1.0 4.0054e-05 1.1 1.20e+01 1.0 0.0e+00 0.0e+00 0.0e+00 1 17 0 0 0 1 17 0 0 0 1
MatAssemblyBegin 1 1.0 3.7909e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 1 0 0 0 5 1 0 0 0 5 0
MatAssemblyEnd 1 1.0 4.3201e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.9e+01 9 0 0 0 46 9 0 0 0 48 0
VecNorm 2 1.0 2.9700e-03 1.0 4.80e+01 1.0 0.0e+00 0.0e+00 2.0e+00 62 67 0 0 5 62 67 0 0 5 0
VecSet 1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 2 1.0 7.8678e-06 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterEnd 2 1.0 4.0531e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSetRandom 1 1.0 9.0599e-06 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 3 0 0 0
Matrix Null Space 1 0 0 0
Vector 5 1 1504 0
Vector Scatter 1 0 0 0
Index Set 2 2 1496 0
PetscRandom 1 1 616 0
Viewer 1 0 0 0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 4.29153e-07
Average time for zero size MPI_Send(): 8.58307e-06
#PETSc Option Table entries:
-log_summary
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Wed Jun 20 12:08:20 2012
Configure options: --with-mpi-dir=/opt/refresco/libraries_cklaij/openmpi-1.4.5 --with-clanguage=c++ --with-x=1 --with-debugging=1 --with-hypre-include=/opt/refresco/libraries_cklaij/hypre-2.7.0b/include --with-hypre-lib=/opt/refresco/libraries_cklaij/hypre-2.7.0b/lib/libHYPRE.a --with-ml-include=/opt/refresco/libraries_cklaij/ml-6.2/include --with-ml-lib=/opt/refresco/libraries_cklaij/ml-6.2/lib/libml.a --with-blas-lapack-dir=/opt/intel/mkl
Libraries compiled on Wed Jun 20 12:08:20 2012 on lin0133
Machine characteristics: Linux-2.6.32-41-generic-x86_64-with-Ubuntu-10.04-lucid
Using PETSc directory: /home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1
Using PETSc arch: linux_64bit_debug
Using C compiler: /opt/refresco/libraries_cklaij/openmpi-1.4.5/bin/mpicxx -wd1572 -g ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /opt/refresco/libraries_cklaij/openmpi-1.4.5/bin/mpif90 -g ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/linux_64bit_debug/include -I/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/include -I/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/include -I/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/linux_64bit_debug/include -I/opt/refresco/libraries_cklaij/hypre-2.7.0b/include -I/opt/refresco/libraries_cklaij/ml-6.2/include -I/opt/refresco/libraries_cklaij/openmpi-1.4.5/include
Using C linker: /opt/refresco/libraries_cklaij/openmpi-1.4.5/bin/mpicxx
Using Fortran linker: /opt/refresco/libraries_cklaij/openmpi-1.4.5/bin/mpif90
Using libraries: -Wl,-rpath,/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/linux_64bit_debug/lib -L/home/CKlaij/ReFRESCO/Dev/trunk/Libs/build/petsc-3.3-p1/linux_64bit_debug/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/opt/refresco/libraries_cklaij/hypre-2.7.0b/lib -L/opt/refresco/libraries_cklaij/hypre-2.7.0b/lib -lHYPRE -Wl,-rpath,/opt/refresco/libraries_cklaij/ml-6.2/lib -L/opt/refresco/libraries_cklaij/ml-6.2/lib -lml -Wl,-rpath,/opt/intel/mkl -L/opt/intel/mkl -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -L/opt/refresco/libraries_cklaij/openmpi-1.4.5/lib -L/opt/intel/composer_xe_2011_sp1.9.293/compiler/lib/intel64 -L/opt/intel/composer_xe_2011_sp1.9.293/ipp/lib/intel64 -L/opt/intel/composer_xe_2011_sp1.9.293/mkl/lib/intel64 -L/opt/intel/composer_xe_2011_sp1.9.293/tbb/lib/intel64/cc4.1.0_libc2.4_kernel2.6.16.21 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lifport -lifcore -lm -lm -lmpi_cxx -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -ldl
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
