[petsc-users] Getting 2d array with updated ghost values from DM	global vector
    TAY wee-beng
    zonexo at gmail.com
    Mon Jul  2 04:58:23 CDT 2012
I have used DMDACreate2d for my code and then use:
call
DMLocalToGlobalBegin(da,b_rhs_semi_local,INSERT_VALUES,b_rhs_semi_global,ierr)
call
DMLocalToGlobalEnd(da,b_rhs_semi_local,INSERT_VALUES,b_rhs_semi_global,ierr)
to construct the global DM vector b_rhs_semi_global
Now I want to get the values with ghost values in a 2d array locally
which is declared as:
real(8), allocatable :: array2d(:,:)
I guess I should use DMDAGetGhostCorners to get the corressponding
indices and allocate it.  But what should I do next? How can I use
something like VecGetArrayF90 to get to the pointer to access the local
vector?
I can't use DMDAVecGetArrayF90/DMDAVecRestoreArrayF90 since I'm using
intel fortran and they can't work. I can't use gfortran at the moment
since I've problems with HYPRE with gfortran in 3D.
Thanks
Yours sincerely,
TAY wee-beng
