[petsc-users] Null space of discrete Laplace with periodic boundary conditions
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Tue Feb 14 16:51:16 CST 2012
Oh sorry.  This is surface Laplacian . My bad
On Feb 14, 2012 2:48 PM, "Jed Brown" <jedbrown at mcs.anl.gov> wrote:
> There is no boundary.
> On Feb 14, 2012 5:47 PM, "Mohammad Mirzadeh" <mirzadeh at gmail.com> wrote:
>> What do you set on the sphere? If you impose a Dirichlet  BC that makes
it nonsingular
>> Mohammad
>> On Feb 14, 2012 7:27 AM, "Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>>> On Tue, Feb 14, 2012 at 09:20, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
>>>> I discretize the Laplace operator (using finite element) on the unit
square equipped with periodic boundary conditions on all four edges. Is it
correct that the null space is still constant? I wounder, because when I
run the same code on a sphere (so a 2D surface embedded in 3D), the
resulting matrix is non-singular. I thought, that both cases should be
somehow equal with respect to the null space?
>>> The continuum operators for both cases have a constant null space, so
if either is nonsingular in your finite element code, it's a discretization
problem.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120214/5c914641/attachment.htm>
