[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Matthew Knepley
knepley at gmail.com
Tue Feb 7 11:29:19 CST 2012
On Tue, Feb 7, 2012 at 11:20 AM, recrusader <recrusader at gmail.com> wrote:
> Whether is it possible to find an efficient mechanism to do the conversion
> between std::complex and cusp::complex when the conversion is necessary.
That does not matter. This is a compile error. We are not going to change
this right now, and it seems like you are not going
make the necessary changes, so I would say that complex numbers are not
supported with our GPU code right now. The
change would involve using cusp::complex for PetscScalar, and I am not sure
how much work that would entail.
Matt
> Thanks.
> Yujie
> On Tue, Feb 7, 2012 at 11:17 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Feb 7, 2012 at 11:15 AM, recrusader <recrusader at gmail.com> wrote:
>>> The following is the reply from Thrust developers,
>>> "The issue here is that the member functions of std::complex are not
>>> decorated with __host__ __device__ and therefore the compiler complains
>>> when asked to instantiate such functions in other __host__ __device__ code.
>>> If you switch std::complex to cusp::complex (which *is* decorated with
>>> __host__ __device__) then the problem should disappear."
>> That makes sense, and my reply is the same. PETSc does not support that
>> complex type. You can try to typedef
>> PetscScalar to that type, but I have no idea what problems it might cause.
>> Matt
>>> Thanks.
>>> On Tue, Feb 7, 2012 at 11:13 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Feb 7, 2012 at 10:19 AM, recrusader <recrusader at gmail.com>wrote:
>>>>> Dear Matt,
>>>>> I got the help from Thrust developers.
>>>>> The problem is
>>>>> in PETSc, we define CUSPARRAY using cusp::array1d<PetscScalar,
>>>>> cusp::device_memory>. Generaly, PetscScalar is std::complex.
>>>>> However, the CUSPARRAY array cannot be decorated at GPU side. We need
>>>>> cusp::array1d<cusp::complex, cusp::device_memory>.
>>>>> Is there any simple method to process this in PETSc?
>>>> This reply does not make any sense to me. What do you mean by the word
>>>> "decorated"? If you mean that they only support the
>>>> complex type cusp::complex, then I advise you to configure for real
>>>> numbers. We do not support cusp::complex as our complex
>>>> type.
>>>> Thanks,
>>>> Matt
>>>>> Thank you very much.
>>>>> Best,
>>>>> Yujie
>>>>> On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com>wrote:
>>>>>>> Thank you very much, Matt,
>>>>>>> You mean the headers of the simple codes, I further simply the codes
>>>>>>> as
>>>>>> This is a question for the CUSP mailing list.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> #include <cusp/blas.h>
>>>>>>> #include <cusp/array1d.h>
>>>>>>> int main(void)
>>>>>>> cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>>>>>> x=new cusp::array1d<std::complex<double>,
>>>>>>> cusp::host_memory>(2,0.0);
>>>>>>> std::complex<double> alpha(1,2.0);
>>>>>>> cusp::blas::scal(*x,alpha);
>>>>>>> return 0;
>>>>>>> I got the same compilation results "
>>>>>>> login1$ nvcc gputest.cu -o gputest
>>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>>>>>>> warning: calling a __host__ function from a __host__ __device__
>>>>>>> function is not allowed
>>>>>>> detected during:
>>>>>>> instantiation of "void
>>>>>>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>>>>>>> T=std::complex<double>, T2=std::complex<double>]"
>>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>>>>>>> here
>>>>>>> instantiation of "InputIterator
>>>>>>> thrust::detail::host::for_each(InputIterator, InputIterator,
>>>>>>> UnaryFunction) [with
>>>>>>> InputIterator=thrust::detail::normal_iterator<std::complex<double>
>>>>>>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>>>>>>> here
>>>>>>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>>>>>>> UnaryFunction, thrust::host_space_tag) [with
>>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>>>>>>> here
>>>>>>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>>>>>>> [with
>>>>>>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>>>>>>> here
>>>>>>> instantiation of "void thrust::for_each(InputIterator,
>>>>>>> InputIterator, UnaryFunction) [with
>>>>>>> (367): here
>>>>>>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator,
>>>>>>> ScalarType)
>>>>>>> [with
>>>>>>> ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>>>>>>> *>, ScalarType=std::complex<double>]"
>>>>>>> (748): here
>>>>>>> instantiation of "void cusp::blas::scal(Array &,
>>>>>>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>>>>>>> cusp::host_memory>, ScalarType=std::complex<double>]"
>>>>>>> gputest.cu(25): here
>>>>>>> Thanks a lot.
>>>>>>> Best,
>>>>>>> Yujie
>>>>>>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>>>>>>> wrote:
>>>>>>> >> Dear PETSc developers,
>>>>>>> >> With your help, I can successfully PETSc-deve with enabling GPU
>>>>>>> and
>>>>>>> >> complex number.
>>>>>>> >> However, when I compiled the codes, I met some errors. I also
>>>>>>> tried to
>>>>>>> >> use simple codes to realize the same function. However, the errors
>>>>>>> >> disappear. One example is as follows:
>>>>>>> >> for the function "VecScale_SeqCUSP"
>>>>>>> >> "#undef __FUNCT__
>>>>>>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>>>>>>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>>>>>>> >> CUSPARRAY *xarray;
>>>>>>> >> PetscErrorCode ierr;
>>>>>>> >> PetscFunctionBegin;
>>>>>>> >> if (alpha == 0.0) {
>>>>>>> >> ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>>>>>>> >> } else if (alpha != 1.0) {
>>>>>>> >> ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>>>> >> try {
>>>>>>> >> cusp::blas::scal(*xarray,alpha);
>>>>>>> >> } catch(char* ex) {
>>>>>>> >> SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>>>>>>> >> ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>>>> >> ierr = WaitForGPU();CHKERRCUSP(ierr);
>>>>>>> >> ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>>>>>>> >> PetscFunctionReturn(0);
>>>>>>> >> When I compiled PETSc-dev, I met the following errors:
>>>>>>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134):
>>>>>>> warning:
>>>>>>> >> calling a __host__ function from a __host__ __device__ function
>>>>>>> is not
>>>>>>> >> allowed
>>>>>>> >> detected during:
>>>>>>> >> T=std::complex<double>, T2=PetscScalar]"
>>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>>>>>>> >> here
>>>>>>> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>>>>>>> >> Size, UnaryFunction>::operator()() [with
>>>>>>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>>> >> Size=long,
>>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>>>>> >> here
>>>>>>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>>>>>>> >> [with
>>>>>>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>>>>>>> >> here
>>>>>>> >> instantiation of "size_t
>>>>>>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>>>>>>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>>>>>>> >> launch_by_value=true]"
>>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>>>>>>> >> here
>>>>>>> >> instantiation of "thrust::pair<size_t, size_t>
>>>>>>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>>>>>>> >> [with
>>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>>>>>>> >> here
>>>>>>> >> [ 6 instantiation contexts not shown ]
>>>>>>> >> UnaryFunction, thrust::device_space_tag) [with
>>>>>>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51):
>>>>>>> here
>>>>>>> UnaryFunction)
>>>>>>> >> [with
>>>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67):
>>>>>>> here
>>>>>>> >> (367): here
>>>>>>> ScalarType)
>>>>>>> >> [with
>>>>>>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>>> >> (748): here
>>>>>>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>>>>>>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>>>>>>> >> veccusp.cu(1185): here
>>>>>>> >> error: a value of type "int" cannot be assigned to an entity of
>>>>>>> type
>>>>>>> >> "_ZNSt7complexIdE9_ComplexTE"
>>>>>>> >> However, I further realize simiar codes as
>>>>>>> >> #include <thrust/version.h>
>>>>>>> >> #include <cusp/version.h>
>>>>>>> >> #include <iostream>
>>>>>>> >> #include <complex>
>>>>>>> >> int main(void)
>>>>>>> >> return 0;
>>>>>>> >> When I complied it using "nvcc gputest.cu -o gputest", I only
>>>>>>> meet
>>>>>>> >> warning information as follows:
>>>>>>> >> detected during:
>>>>>>> >> here
>>>>>>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>>>>>>> >> here
>>>>>>> >> here
>>>>>>> UnaryFunction)
>>>>>>> >> [with
>>>>>>> >> here
>>>>>>> >> (367): here
>>>>>>> ScalarType)
>>>>>>> >> [with
>>>>>>> >> (748): here
>>>>>>> >> There are not errors like
>>>>>>> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>>>>> type
>>>>>>> >> "_ZNSt7complexIdE9_ComplexTE" "
>>>>>>> >> Furthermore, the warning information is also different between
>>>>>>> >> PETSc-dev and simple codes.
>>>>>>> >> Could you give me some suggestion for this errors? Thank you very
>>>>>>> much.
>>>>>>> > The headers are complicated to get right. The whole point of what
>>>>>>> we did is
>>>>>>> > to give a way to use GPU
>>>>>>> > simply through the existing PETSc linear algebra interface.
>>>>>>> > Matt
>>>>>>> >> Best,
>>>>>>> >> Yujie
>>>>>>> > What most experimenters take for granted before they begin their
>>>>>>> > experiments is infinitely more interesting than any results to
>>>>>>> which their
>>>>>>> > experiments lead.
>>>>>>> > -- Norbert Wiener
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/c1dba01d/attachment-0001.htm>
