[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
recrusader recrusader at gmail.com
Tue Feb 7 11:20:31 CST 2012
Whether is it possible to find an efficient mechanism to do the conversion
between std::complex and cusp::complex when the conversion is necessary.
Thanks.
Yujie
On Tue, Feb 7, 2012 at 11:17 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 7, 2012 at 11:15 AM, recrusader <recrusader at gmail.com> wrote:
>> The following is the reply from Thrust developers,
>> "The issue here is that the member functions of std::complex are not
>> decorated with __host__ __device__ and therefore the compiler complains
>> when asked to instantiate such functions in other __host__ __device__ code.
>>  If you switch std::complex to cusp::complex (which *is* decorated with
>> __host__ __device__) then the problem should disappear."
> That makes sense, and my reply is the same. PETSc does not support that
> complex type. You can try to typedef
> PetscScalar to that type, but I have no idea what problems it might cause.
>    Matt
>> Thanks.
>> On Tue, Feb 7, 2012 at 11:13 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Feb 7, 2012 at 10:19 AM, recrusader <recrusader at gmail.com>wrote:
>>>> Dear Matt,
>>>> I got the help from Thrust developers.
>>>> The problem is
>>>> in PETSc, we define CUSPARRAY using cusp::array1d<PetscScalar,
>>>> cusp::device_memory>. Generaly, PetscScalar is std::complex.
>>>> However, the CUSPARRAY array cannot be decorated at GPU side. We need
>>>> cusp::array1d<cusp::complex, cusp::device_memory>.
>>>> Is there any simple method to process this in PETSc?
>>> This reply does not make any sense to me. What do you mean by the word
>>> "decorated"? If you mean that they only support the
>>> complex type cusp::complex, then I advise you to configure for real
>>> numbers. We do not support cusp::complex as our complex
>>> type.
>>>   Thanks,
>>>      Matt
>>>> Thank you very much.
>>>> Best,
>>>> Yujie
>>>> On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com>wrote:
>>>>>> Thank you very much, Matt,
>>>>>> You mean the headers of the simple codes, I further simply the codes
>>>>>> as
>>>>> This is a question for the CUSP mailing list.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> #include <cusp/blas.h>
>>>>>> #include <cusp/array1d.h>
>>>>>> int main(void)
>>>>>>    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>>>>>    x=new cusp::array1d<std::complex<double>,
>>>>>> cusp::host_memory>(2,0.0);
>>>>>>    std::complex<double> alpha(1,2.0);
>>>>>>    cusp::blas::scal(*x,alpha);
>>>>>>    return 0;
>>>>>> I got the same compilation results "
>>>>>> login1$ nvcc gputest.cu -o gputest
>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>>>>>> warning: calling a __host__ function from a __host__ __device__
>>>>>> function is not allowed
>>>>>>          detected during:
>>>>>>            instantiation of "void
>>>>>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>>>>>> T=std::complex<double>, T2=std::complex<double>]"
>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>>>>>> here
>>>>>>            instantiation of "InputIterator
>>>>>> thrust::detail::host::for_each(InputIterator, InputIterator,
>>>>>> UnaryFunction) [with
>>>>>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>>>>>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>>>>>> here
>>>>>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>>>>>> UnaryFunction, thrust::host_space_tag) [with
>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>>>>>> here
>>>>>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>>>>>> [with
>>>>>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>>>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>>>>>> here
>>>>>>            instantiation of "void thrust::for_each(InputIterator,
>>>>>> InputIterator, UnaryFunction) [with
>>>>>> (367): here
>>>>>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
>>>>>> [with
>>>>>> ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>>>>>> *>, ScalarType=std::complex<double>]"
>>>>>> (748): here
>>>>>>            instantiation of "void cusp::blas::scal(Array &,
>>>>>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>>>>>> cusp::host_memory>, ScalarType=std::complex<double>]"
>>>>>> gputest.cu(25): here
>>>>>> Thanks a lot.
>>>>>> Best,
>>>>>> Yujie
>>>>>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>>>>>> wrote:
>>>>>> >> Dear PETSc developers,
>>>>>> >> With your help, I can successfully PETSc-deve with enabling GPU and
>>>>>> >> complex number.
>>>>>> >> However, when I compiled the codes, I met some errors. I also
>>>>>> tried to
>>>>>> >> use simple codes to realize the same function. However, the errors
>>>>>> >> disappear. One example is as follows:
>>>>>> >> for the function "VecScale_SeqCUSP"
>>>>>> >> "#undef __FUNCT__
>>>>>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>>>>>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>>>>>> >>  CUSPARRAY      *xarray;
>>>>>> >>  PetscErrorCode ierr;
>>>>>> >>  PetscFunctionBegin;
>>>>>> >>  if (alpha == 0.0) {
>>>>>> >>    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>>>>>> >>  } else if (alpha != 1.0) {
>>>>>> >>    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>>> >>    try {
>>>>>> >>      cusp::blas::scal(*xarray,alpha);
>>>>>> >>    } catch(char* ex) {
>>>>>> >>      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>>>>>> >>    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>>>>> >>  ierr = WaitForGPU();CHKERRCUSP(ierr);
>>>>>> >>  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>>>>>> >>  PetscFunctionReturn(0);
>>>>>> >> When I compiled PETSc-dev, I met the following errors:
>>>>>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134):
>>>>>> warning:
>>>>>> >> calling a __host__ function from a __host__ __device__ function is
>>>>>> not
>>>>>> >> allowed
>>>>>> >>          detected during:
>>>>>> >> T=std::complex<double>, T2=PetscScalar]"
>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>>>>>> >> here
>>>>>> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>>>>>> >> Size, UnaryFunction>::operator()() [with
>>>>>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>> >> Size=long,
>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>>>> >> here
>>>>>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>>>>>> >> [with
>>>>>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>>>>>> >> here
>>>>>> >>            instantiation of "size_t
>>>>>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>>>>>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>>>>>> >> launch_by_value=true]"
>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>>>>>> >> here
>>>>>> >>            instantiation of "thrust::pair<size_t, size_t>
>>>>>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>>>>>> >> [with
>>>>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>>>>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>>>>>> >> here
>>>>>> >>            [ 6 instantiation contexts not shown ]
>>>>>> >> UnaryFunction, thrust::device_space_tag) [with
>>>>>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51):
>>>>>> here
>>>>>> UnaryFunction)
>>>>>> >> [with
>>>>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67):
>>>>>> here
>>>>>> >> (367): here
>>>>>> ScalarType)
>>>>>> >> [with
>>>>>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>>>>> >> (748): here
>>>>>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>>>>>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>>>>>> >> veccusp.cu(1185): here
>>>>>> >> error: a value of type "int" cannot be assigned to an entity of
>>>>>> type
>>>>>> >> "_ZNSt7complexIdE9_ComplexTE"
>>>>>> >> However, I further realize simiar codes as
>>>>>> >> #include <thrust/version.h>
>>>>>> >> #include <cusp/version.h>
>>>>>> >> #include <iostream>
>>>>>> >> #include <complex>
>>>>>> >> int main(void)
>>>>>> >>    return 0;
>>>>>> >> When I complied it using  "nvcc gputest.cu -o gputest", I only
>>>>>> meet
>>>>>> >> warning information as follows:
>>>>>> >>          detected during:
>>>>>> >> here
>>>>>> >> here
>>>>>> >> here
>>>>>> UnaryFunction)
>>>>>> >> [with
>>>>>> >> here
>>>>>> >> (367): here
>>>>>> ScalarType)
>>>>>> >> [with
>>>>>> >> (748): here
>>>>>> >> There are not errors like
>>>>>> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>>>>> type
>>>>>> >> "_ZNSt7complexIdE9_ComplexTE" "
>>>>>> >> Furthermore, the warning information is also different between
>>>>>> >> PETSc-dev and simple codes.
>>>>>> >> Could you give me some suggestion for this errors? Thank you very
>>>>>> much.
>>>>>> > The headers are complicated to get right. The whole point of what
>>>>>> we did is
>>>>>> > to give a way to use GPU
>>>>>> > simply through the existing PETSc linear algebra interface.
>>>>>> >    Matt
>>>>>> >> Best,
>>>>>> >> Yujie
>>>>>> > What most experimenters take for granted before they begin their
>>>>>> > experiments is infinitely more interesting than any results to
>>>>>> which their
>>>>>> > experiments lead.
>>>>>> > -- Norbert Wiener
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/104ff41b/attachment-0001.htm>
