[petsc-users] MG Preconditioning
Gaetan Kenway
kenway at utias.utoronto.ca
Fri Aug 31 22:03:54 CDT 2012
Hi again
I distilled the problem down further to a simple subroutine in mgtest.F,
copied directly from ex8f.F
subroutine MGTest()
implicit none
#include "include/finclude/petsc.h"
KSP ksp
PC pc
PetscErrorCode ierr
PetscInt nlevels, two
two = 2
call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
call KSPGetPC(ksp,pc,ierr)
call PCSetType(pc,PCMG,ierr)
call PCMGSetLevels(pc,two,PETSC_NULL_OBJECT,ierr)
call KSPDestroy(ksp)
end subroutine MGTest
When I ran this simple case with gdb I got the following backtrace:
#0 0xb694d465 in PMPI_Attr_get () from /usr/local/lib/libmpi.so.0
#1 0xb555d7c9 in PetscCommDuplicate (comm_in=0x0, comm_out=0x88d7378,
first_tag=0x88d73a0) at
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/sys/objects/tagm.c:145
#2 0xb5562ef7 in PetscHeaderCreate_Private (h=0x88d7370, classid=1211235,
type=-1, class_name=0xb61cfd70 "KSP", descr=0xb61cfd74 "Krylov Method",
mansec=0xb61cfd70 "KSP", comm=0x0,
des=0xb5eeac70 <KSPDestroy>, vie=0xb5efafd7 <KSPView>) at
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/sys/objects/inherit.c:51
#3 0xb5eff7ca in KSPCreate (comm=0x0, inksp=0x88d6ee0) at
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itcreate.c:564
#4 0xb5d4ac3a in PCMGSetLevels (pc=0x89089a0, levels=2, comms=0xb4bbf5a0)
at /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c:219
#5 0xb5d2c73c in pcmgsetlevels_ (pc=0xbfffec98, levels=0xbfffec8c,
comms=0xb4bbf5a0, ierr=0xbfffec94) at
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/ftn-custom/zmgf.c:15
#6 0xb4affe1d in mgtest () at mgtest.F:15
#7 0xb4aad769 in f2py_rout_warp_mgtest (capi_self=0x8618758,
capi_args=0xb7c3002c, capi_keywds=0x0, f2py_func=0xb4affdc0 <mgtest>) at
warpmodule.c:4273
#8 0xb4aa58cf in fortran_call (fp=0x8618758, arg=0xb7c3002c, kw=0x0) at
/usr/lib/python2.6/dist-packages/numpy/f2py/src/fortranobject.c:318
#9 0x0805fd6a in PyObject_Call ()
#10 0x080dd5b0 in PyEval_EvalFrameEx ()
#11 0x080dfbb2 in PyEval_EvalCodeEx ()
#12 0x080dfca7 in PyEval_EvalCode ()
#13 0x080fd956 in PyRun_FileExFlags ()
#14 0x080fdbb2 in PyRun_SimpleFileExFlags ()
#15 0x0805b6d3 in Py_Main ()
#16 0x0805a8ab in main ()
The only difference is that I'm calling the routine from python and petsc
is initialized from petsc4py.
Any ideas?
Gaetan
On Fri, Aug 31, 2012 at 9:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> src/ksp/pc/examples/tests/ex8f.F is a simple example, but I made the
> modification below and it runs fine.
> diff --git a/src/ksp/pc/examples/tests/ex8f.F
> b/src/ksp/pc/examples/tests/ex8f.F
> --- a/src/ksp/pc/examples/tests/ex8f.F
> +++ b/src/ksp/pc/examples/tests/ex8f.F
> @@ -35,7 +35,7 @@
> Vec x,b,u
> PC pc
> PetscInt n,dim,istart,iend
> - PetscInt i,j,jj,ii,one,zero
> + PetscInt i,j,jj,ii,one,two,zero
> PetscErrorCode ierr
> PetscScalar v
> external MyResidual
> @@ -50,6 +50,7 @@
> pfive = .5d0
> n = 6
> dim = n*n
> + two = 2
> one = 1
> zero = 0
> @@ -138,7 +139,7 @@
> - call PCMGSetLevels(pc,one,PETSC_NULL_OBJECT,ierr)
> + call PCMGSetLevels(pc,two,PETSC_NULL_OBJECT,ierr)
> call PCMGSetResidual(pc,zero,PCMGDefaultResidual,A,ierr)
> call PCMGSetResidual(pc,zero,MyResidual,A,ierr)
> @@ -147,6 +148,7 @@
> ! also serves as the preconditioning matrix.
> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> + call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD,ierr)
> call KSPDestroy(ksp,ierr)
> $ mpirun.hydra -n 2 ./ex8f
> KSP Object: 2 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: 2 MPI processes
> type: mg
> MG: type is MULTIPLICATIVE, levels=2 cycles=v
> Cycles per PCApply=1
> Not using Galerkin computed coarse grid matrices
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_coarse_) 2 MPI processes
> type: preonly
> maximum iterations=1, initial guess is zero
> using NONE norm type for convergence test
> PC Object: (mg_coarse_) 2 MPI processes
> type: redundant
> Redundant preconditioner: Not yet setup
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object: (mg_levels_1_) 2 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0, max = 0
> maximum iterations=2, initial guess is zero
> PC Object: (mg_levels_1_) 2 MPI processes
> type: sor
> SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1
> Up solver (post-smoother) same as down solver (pre-smoother)
> linear system matrix = precond matrix:
> Matrix Object: 2 MPI processes
> type: mpiaij
> rows=36, cols=36
> total: nonzeros=156, allocated nonzeros=252
> total number of mallocs used during MatSetValues calls =0
> not using I-node (on process 0) routines
> On Fri, Aug 31, 2012 at 7:27 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>> Hi
>> I'm having an issue with the PCMG preconditioner in PETSc. I'm trying to
>> use PCMG to precondition a linear system of equations resulting from the
>> discretization of the EUler equations. It is from a multi-block code so I
>> have the ability to easily generate restriction operators using geometric
>> method.
>> I'm currently trying to setup a simple 2V cycle. For this I use:
>> ! Create the restriction operator between finest level and one below
>> call createRestrictOperator(RL1, 1)
>> call PCSetFromOptions(pc, PETScIerr)
>> nlevels=2
>> !call PCMGSetLevels(pc, nlevels, PETSC_NULL_OBJECT,PETScIerr) ! Doesn't
>> work from fortran!!!
>> call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
>> call PCMGSetRestriction(pc, 1, RL1, PETScierr)
>> call PCView(pc, PETScierr)
>> I run with the command line argument -pc_mg_levels 2 .
>> First issue: PCMGSetLevels does not work correctly from Fortran. The
>> traceback I get when I run (with the commented-out line above and without
>> the command line arguments) is:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>> corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: --------------------- Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>> [0]PETSC ERROR: is given.
>> [0]PETSC ERROR: [0] PetscCommDuplicate line 144
>> [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 30
>> [0]PETSC ERROR: [0] KSPCreate line 557
>> [0]PETSC ERROR: [0] PCMGSetLevels line 180
>> I can get around that issue by using -pc_mg_levels 2 and not calling the
>> PCMGSetLevels() command, but I would like to actually use this command and
>> not have set it via manually setting an option. The result of the PCView is
>> listed below which appears to be what I expect (given the default options)
>> PC Object: 1 MPI processes
>> type: mg
>> Using Galerkin computed coarse grid matrices
>> KSP Object: (mg_coarse_) 1 MPI processes
>> type: preonly
>> PC Object: (mg_coarse_) 1 MPI processes
>> type: lu
>> LU: out-of-place factorization
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: nd
>> KSP Object: (mg_levels_1_) 1 MPI processes
>> type: chebyshev
>> PC Object: (mg_levels_1_) 1 MPI processes
>> type: sor
>> 1, omega = 1
>> linear system matrix followed by preconditioner matrix:
>> Matrix Object: 1 MPI processes
>> type: seqbaij
>> rows=92160, cols=92160, bs=5
>> total: nonzeros=5582400, allocated nonzeros=5582400
>> block size is 5
>> type: seqbaij
>> total: nonzeros=3089600, allocated nonzeros=3089600
>> block size is 5
>> So that's ok. When it gets to actually solving my system with KSPSolve()
>> I get a returned error code 73 which is "object in argument is in wrong
>> state, e.g. unassembled mat"
> In general, please don't paraphrase error messages.
> With these problems, try running in a debugger to get a real trace and
> with valgrind. The most common problem is stack corruption due to passing
> the wrong number or types of arguments.
>> and the traceback is:
>> available,
>> [0]PETSC ERROR: [0] MatGetVecs line 8142
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
>> [0]PETSC ERROR: [0] KSPGetVecs line 774
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
>> [0]PETSC ERROR: [0] PCSetUp_MG line 508
>> [0]PETSC ERROR: [0] PCSetUp line 810
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: [0] KSPSetUp line 182
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: [0] KSPSolve line 351
>> Which would indicate to me its an issue with one of the matrices
>> involved, either the linear operator, A, the preconditioner P or my
>> provided restriction matrix RL1. A and P i'm pretty sure are OK, since it
>> works just fine when I use my usual BlockJacobi/Additive Schwartz with
>> ILU(k) on the subdomains. Which leaves the Restriction operator as the
>> issue. I added the following code before PCView()
>> call MatGetVecs(RL1, vec1, vec2, ierr)
>> call VecSet(vec1, 1.0, ierr)
>> call MatMult(RL1, vec1, vec2, ierr)
>> which ran through just fine (I check each of the ierrs but those are not
>> shown).
>> So I'm at a loss as to what is causing the error.
>> I'm using an up-to-date copy of petsc-3.3 from the repository.
>> Thanks,
>> Gaetan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120831/619e3d4b/attachment.html>
