[petsc-users] MG Preconditioning
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 31 21:37:13 CDT 2012
You should try running your code with valgrind. It could be the memory corruption is early and just happens to appear here.
Barry
On Aug 31, 2012, at 8:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> src/ksp/pc/examples/tests/ex8f.F is a simple example, but I made the modification below and it runs fine.
> diff --git a/src/ksp/pc/examples/tests/ex8f.F b/src/ksp/pc/examples/tests/ex8f.F
> --- a/src/ksp/pc/examples/tests/ex8f.F
> +++ b/src/ksp/pc/examples/tests/ex8f.F
> @@ -35,7 +35,7 @@
> Vec x,b,u
> PC pc
> PetscInt n,dim,istart,iend
> - PetscInt i,j,jj,ii,one,zero
> + PetscInt i,j,jj,ii,one,two,zero
> PetscErrorCode ierr
> PetscScalar v
> external MyResidual
> @@ -50,6 +50,7 @@
> pfive = .5d0
> n = 6
> dim = n*n
> + two = 2
> one = 1
> zero = 0
> @@ -138,7 +139,7 @@
> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> call KSPGetPC(ksp,pc,ierr)
> call PCSetType(pc,PCMG,ierr)
> - call PCMGSetLevels(pc,one,PETSC_NULL_OBJECT,ierr)
> + call PCMGSetLevels(pc,two,PETSC_NULL_OBJECT,ierr)
> call PCMGSetResidual(pc,zero,PCMGDefaultResidual,A,ierr)
> call PCMGSetResidual(pc,zero,MyResidual,A,ierr)
> @@ -147,6 +148,7 @@
> ! also serves as the preconditioning matrix.
> call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> + call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD,ierr)
> call KSPDestroy(ksp,ierr)
> $ mpirun.hydra -n 2 ./ex8f
> KSP Object: 2 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using DEFAULT norm type for convergence test
> PC Object: 2 MPI processes
> type: mg
> MG: type is MULTIPLICATIVE, levels=2 cycles=v
> Cycles per PCApply=1
> Not using Galerkin computed coarse grid matrices
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_coarse_) 2 MPI processes
> type: preonly
> maximum iterations=1, initial guess is zero
> using NONE norm type for convergence test
> PC Object: (mg_coarse_) 2 MPI processes
> type: redundant
> Redundant preconditioner: Not yet setup
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object: (mg_levels_1_) 2 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0, max = 0
> maximum iterations=2, initial guess is zero
> PC Object: (mg_levels_1_) 2 MPI processes
> type: sor
> SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
> Up solver (post-smoother) same as down solver (pre-smoother)
> linear system matrix = precond matrix:
> Matrix Object: 2 MPI processes
> type: mpiaij
> rows=36, cols=36
> total: nonzeros=156, allocated nonzeros=252
> total number of mallocs used during MatSetValues calls =0
> not using I-node (on process 0) routines
> On Fri, Aug 31, 2012 at 7:27 PM, Gaetan Kenway <kenway at utias.utoronto.ca> wrote:
> Hi
> I'm having an issue with the PCMG preconditioner in PETSc. I'm trying to use PCMG to precondition a linear system of equations resulting from the discretization of the EUler equations. It is from a multi-block code so I have the ability to easily generate restriction operators using geometric method.
> I'm currently trying to setup a simple 2V cycle. For this I use:
> ! Create the restriction operator between finest level and one below
> call createRestrictOperator(RL1, 1)
> call PCSetFromOptions(pc, PETScIerr)
> nlevels=2
> !call PCMGSetLevels(pc, nlevels, PETSC_NULL_OBJECT,PETScIerr) ! Doesn't work from fortran!!!
> call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
> call PCMGSetRestriction(pc, 1, RL1, PETScierr)
> call PCView(pc, PETScierr)
> I run with the command line argument -pc_mg_levels 2 .
> First issue: PCMGSetLevels does not work correctly from Fortran. The traceback I get when I run (with the commented-out line above and without the command line arguments) is:
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] PetscCommDuplicate line 144 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/sys/objects/tagm.c
> [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 30 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/sys/objects/inherit.c
> [0]PETSC ERROR: [0] KSPCreate line 557 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itcreate.c
> [0]PETSC ERROR: [0] PCMGSetLevels line 180 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
> I can get around that issue by using -pc_mg_levels 2 and not calling the PCMGSetLevels() command, but I would like to actually use this command and not have set it via manually setting an option. The result of the PCView is listed below which appears to be what I expect (given the default options)
> PC Object: 1 MPI processes
> type: mg
> Using Galerkin computed coarse grid matrices
> KSP Object: (mg_coarse_) 1 MPI processes
> type: preonly
> PC Object: (mg_coarse_) 1 MPI processes
> type: lu
> LU: out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> matrix ordering: nd
> KSP Object: (mg_levels_1_) 1 MPI processes
> type: chebyshev
> PC Object: (mg_levels_1_) 1 MPI processes
> type: sor
> linear system matrix followed by preconditioner matrix:
> Matrix Object: 1 MPI processes
> type: seqbaij
> rows=92160, cols=92160, bs=5
> total: nonzeros=5582400, allocated nonzeros=5582400
> block size is 5
> type: seqbaij
> total: nonzeros=3089600, allocated nonzeros=3089600
> block size is 5
> So that's ok. When it gets to actually solving my system with KSPSolve() I get a returned error code 73 which is "object in argument is in wrong state, e.g. unassembled mat"
> In general, please don't paraphrase error messages.
> With these problems, try running in a debugger to get a real trace and with valgrind. The most common problem is stack corruption due to passing the wrong number or types of arguments.
> and the traceback is:
> [0]PETSC ERROR: [0] MatGetVecs line 8142 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] KSPGetVecs line 774 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: [0] PCSetUp_MG line 508 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: [0] PCSetUp line 810 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 182 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 351 /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itfunc.c
> Which would indicate to me its an issue with one of the matrices involved, either the linear operator, A, the preconditioner P or my provided restriction matrix RL1. A and P i'm pretty sure are OK, since it works just fine when I use my usual BlockJacobi/Additive Schwartz with ILU(k) on the subdomains. Which leaves the Restriction operator as the issue. I added the following code before PCView()
> call MatGetVecs(RL1, vec1, vec2, ierr)
> call VecSet(vec1, 1.0, ierr)
> call MatMult(RL1, vec1, vec2, ierr)
> which ran through just fine (I check each of the ierrs but those are not shown).
> So I'm at a loss as to what is causing the error.
> I'm using an up-to-date copy of petsc-3.3 from the repository.
> Thanks,
> Gaetan
