[petsc-users] pctype hmpi
Fri Aug 31 16:04:55 CDT 2012
   Yikes. It is totally my fault.  The handling of these merge and spawn options is done only for PetscInitialize() for C. Not for Fortran, hence the arguments just got ignored.
    Please find attached a file zstart.c   put it in the directory src/sys/ftn-custom  and run make in that directory (with appropriate PETSC_DIR and PETSC_ARCH set)
    Then link and run the example again.
   Barry
On Aug 31, 2012, at 3:30 PM, George Pau <gpau at lbl.gov> wrote:
> Sorry, it was a cut and paste error.  I tried running the code with all the options in the command line:
> mpiexec.mpich2 -n 1 xt2_eos4 -hmpi_spawn_size 3 -pc_type hmpi -ksp_type preonly -hmpi_ksp_type cg -hmpi_pc_type hypre -hmpi_pc_hypre boomeramg
> mpiexec.mpich2 -n 2 xt2_eos4 -hmpi_merge_size 2 -pc_type hmpi -ksp_type preonly -hmpi_ksp_type cg -hmpi_pc_type hypre -hmpi_pc_hypre boomeramg
> but I get the exact same outputs.
> George
> On Fri, Aug 31, 2012 at 1:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 31, 2012, at 3:09 PM, George Pau <gpau at lbl.gov> wrote:
> > Hi Barry,
> > For the hmpi_spawn_size,  the options in my .petscrc are
> > -info
> > -pc_view
> > pc_type hmpi
>   How come there is no - in front of this one?
> > -ksp_type preonly
> > -ksp_view
> > -hmpi_pc_monitor
> > -hmpi_ksp_monitor
> > -hmpi_ksp_type cg
> > -hmpi_pc_type hypre
> > -hmpi_pc_hypre_type boomeramg
> > -hmpi_spawn_size 3
> > mpiexec.mpich2 -n 1 myprogram
> > [0] petscinitialize_(): (Fortran):PETSc successfully started: procs 1
> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS gilbert.(none)
> > [0] petscinitialize_(): Running on machine: gilbert
> > [0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374784 max tags = 2147483647
> > [0] MatSetUp(): Warning not preallocating matrix storage
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 360 X 360; storage space: 3978 unneeded,3222 used
> > [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 360
> > [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 9
> > [0] Mat_CheckInode(): Found 120 nodes of 360. Limit used: 5. Using Inode routines
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374784
> > Fatal error in PMPI_Bcast: Invalid communicator, error stack:
> > PMPI_Bcast(1478): MPI_Bcast(buf=0x7fff30dacecc, count=1, MPI_INT, root=0, comm=0x0) failed
> > PMPI_Bcast(1418): Invalid communicator
> > I inserted some print statement between the ksp calls and found that the error occurs in
> > call KSPSetFromOptions(ksp, pierr)
> > 2. If I change hmpi_spawn_size 3 to hmpi_merge_size 2 and launch my job by
>    How come there is no - in front of hmpi_merge_size 2?
>    Can you try putting all the arguments as command line arguments instead of in a file? It shouldn't matter but it seems like some of the arguments are being ignored.
>    Barry
> > mpiexec.mpich2 -n 2 myprogram
> > [0] petscinitialize_(): (Fortran):PETSc successfully started: procs 2
> > [1] petscinitialize_(): (Fortran):PETSc successfully started: procs 2
> > [1] PetscGetHostName(): Rejecting domainname, likely is NIS gilbert.(none)
> > [1] petscinitialize_(): Running on machine: gilbert
> > [0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374780 max tags = 2147483647
> > [1] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 2147483647
> > [0] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374777 max tags = 2147483647
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374777
> > [1] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 2147483647
> > [1] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
> > [0] MatStashScatterBegin_Private(): No of messages: 1
> > [0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 12896
> > [0] MatAssemblyBegin_MPIAIJ(): Stash has 1611 entries, uses 0 mallocs.
> > [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 180; storage space: 1998 unneeded,1602 used
> > [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 180
> > [0] Mat_CheckInode(): Found 60 nodes of 180. Limit used: 5. Using Inode routines
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 180; storage space: 1998 unneeded,1602 used
> > [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 180
> > [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 9
> > [1] Mat_CheckInode(): Found 60 nodes of 180. Limit used: 5. Using Inode routines
> > [0] VecScatterCreateCommon_PtoS(): Using blocksize 1 scatter
> > [0] VecScatterCreate(): General case: MPI to Seq
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 3; storage space: 396 unneeded,9 used
> > [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 3
> > [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
> > [1] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 3; storage space: 396 unneeded,9 used
> > [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374780
> > [0] VecAssemblyBegin_MPI(): Stash has 180 entries, uses 1 mallocs.
> > [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
> > [0] PCSetUp(): Setting up new PC
> > [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> > [0]PETSC ERROR: Nonconforming object sizes!
> > [0]PETSC ERROR: HMPI preconditioner only works for sequential solves!
> > [0]PETSC ERROR: ------------------------------------------------------------------------
> > [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR: ../../esd-tough2/xt2_eos4 on a arch-linu named gilbert by gpau Fri Aug 31 13:00:31 2012
> > [0]PETSC ERROR: Libraries linked from /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/lib
> > [0]PETSC ERROR: Configure run at Thu Aug 30 15:27:17 2012
> > [0]PETSC ERROR: Configure options --with-debugging=0 --with-mpi-dir=/usr/lib/mpich2 --download-hypre=1 --prefix=/home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib
> > [0]PETSC ERROR: PCCreate_HMPI() line 283 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/impls/openmp/hpc.c
> > [0]PETSC ERROR: PCSetType() line 83 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/interface/pcset.c
> > [0]PETSC ERROR: PCSetFromOptions() line 188 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/interface/pcset.c
> > [0]PETSC ERROR: KSPSetFromOptions() line 287 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itcl.c
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: PC does not have apply!
> > [0]PETSC ERROR: PCApply() line 382 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: KSPInitialResidual() line 64 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itres.c
> > [0]PETSC ERROR: KSPSolve_GMRES() line 230 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/impls/gmres/gmres.c
> > [0]PETSC ERROR: KSPSolve() line 446 in /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itfunc.c
> > I note that the error appears to occur at the same point.
> > George
> > On Fri, Aug 31, 2012 at 11:31 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Aug 31, 2012, at 1:27 PM, George Pau <gpau at lbl.gov> wrote:
> > > Hi Barry,
> > > 1. It is the exact same error related to MPI_ERR_COMM and MPI_Bcast.
> >    That should not happen. Please run and send all the output including the exact command line used
> > >  I am currently using the MPICH2 distribution provided by ubuntu but if MPICH version that Petsc download with -download-mpich works, I can use that.
> > > 2. If I use hmpi_merge_size, I will need to launch mpiexec with more than 1 cpus.  But, petsc will complain that the pctype hmpi can only be used in serial.
> >    That should not happen. Run with 2 MPI processes and -hmpi_merge_size 2  and send the complete error message.
> >   Barry
> > > George
> > > On Aug 31, 2012, at 11:17 AM, Barry Smith wrote:
> > >> On Aug 30, 2012, at 10:02 PM, George Pau <gpau at lbl.gov> wrote:
> > >>> Hi Barry,
> > >>> I tried with the addition of
> > >>> -hmpi_spawn_size 3
> > >>> but I am still getting the same error though.
> > >>   The EXACT same error? Or some other error?
> > >>    What happens if you run with the -hmpi_merge_size <size> option instead?
> > >>  Barry
> > >> 1) I am getting a crash with the spawn version I suspect is due to bugs in the MPICH version I am using related to spawn.
> > >> 2) I am getting errors with the merge version due to Apple's ASLR which they make hard to turn off.
> > >>> I am using mpich2.  Any other options to try?
> > >>> George
> > >>> On Aug 30, 2012, at 7:28 PM, Barry Smith wrote:
> > >>>> On Aug 30, 2012, at 7:24 PM, George Pau <gpau at lbl.gov> wrote:
> > >>>>> Hi,
> > >>>>> I have some issues using the -pctype hmpi.  I used the same setting found at
> > >>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHMPI.html
> > >>>>> i.e.
> > >>>>> -pc_type hmpi
> > >>>>> -ksp_type preonly
> > >>>>> -hmpi_ksp_type cg
> > >>>>> -hmpi_pc_type hypre
> > >>>>> My command  is
> > >>>>> mpiexec -n 1 myprogram
> > >>>> Sorry the documentation doesn't make this clearer. You need to start PETSc with special options to get the "worker" processes initialized. From the manual page for PCHMPI it has
> > >>>> See PetscHMPIMerge() and PetscHMPISpawn() for two ways to start up MPI for use with this preconditioner
> > >>>> This will tell you want option to start PETSc up with.
> > >>>> I will fix the PC so that it prints a far more useful error message.
> > >>>> Barry
> > >>>>> But, I get
> > >>>>> [gilbert:4041] *** An error occurred in MPI_Bcast
> > >>>>> [gilbert:4041] *** on communicator MPI_COMM_WORLD
> > >>>>> [gilbert:4041] *** MPI_ERR_COMM: invalid communicator
> > >>>>> [gilbert:4041] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
> > >>>>> with openmpi.  I get similar error with mpich2
> > >>>>> PMPI_Bcast(1478): MPI_Bcast(buf=0x7fffb683479c, count=1, MPI_INT, root=0, comm=0x0) failed
> > >>>>> I couldn't figure out what is wrong.    My petsc is  version 3.3.3 and the configuration is -with-debugging=0 --with-mpi-dir=/usr/lib/openmpi --download-hypre=1 and I am on a Ubuntu machine.
> > >>>>> Note that with the default pc_type and ksp_type, everything is fine.  It was also tested with multiple processors.  I wondering whether there are some options that I am not specifying correctly?
> > >>>>> George Pau
> > >>>>> Earth Sciences Division
> > >>>>> Lawrence Berkeley National Laboratory
> > >>>>> One Cyclotron, MS 74-120
> > >>>>> Berkeley, CA 94720
> > >>>>> (510) 486-7196
> > >>>>> gpau at lbl.gov
> > >>>>> http://esd.lbl.gov/about/staff/georgepau/
> > George Pau
> > Berkeley, CA 94720
> > (510) 486-7196
> > gpau at lbl.gov
> George Pau
> Berkeley, CA 94720
> (510) 486-7196
> gpau at lbl.gov
