[petsc-users] pctype hmpi
George Pau gpau at lbl.gov
Fri Aug 31 15:30:35 CDT 2012
Sorry, it was a cut and paste error.  I tried running the code with all the
options in the command line:
mpiexec.mpich2 -n 1 xt2_eos4 -hmpi_spawn_size 3 -pc_type hmpi -ksp_type
preonly -hmpi_ksp_type cg -hmpi_pc_type hypre -hmpi_pc_hypre boomeramg
mpiexec.mpich2 -n 2 xt2_eos4 -hmpi_merge_size 2 -pc_type hmpi -ksp_type
but I get the exact same outputs.
George
On Fri, Aug 31, 2012 at 1:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 31, 2012, at 3:09 PM, George Pau <gpau at lbl.gov> wrote:
> > Hi Barry,
> > For the hmpi_spawn_size,  the options in my .petscrc are
> > -info
> > -pc_view
> > pc_type hmpi
>   How come there is no - in front of this one?
> > -ksp_type preonly
> > -ksp_view
> > -hmpi_pc_monitor
> > -hmpi_ksp_monitor
> > -hmpi_ksp_type cg
> > -hmpi_pc_type hypre
> > -hmpi_pc_hypre_type boomeramg
> > -hmpi_spawn_size 3
> > mpiexec.mpich2 -n 1 myprogram
> > [0] petscinitialize_(): (Fortran):PETSc successfully started: procs 1
> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> gilbert.(none)
> > [0] petscinitialize_(): Running on machine: gilbert
> > [0] PetscCommDuplicate(): Duplicating a communicator 1140850688
> -2080374784 max tags = 2147483647
> > [0] MatSetUp(): Warning not preallocating matrix storage
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 360 X 360; storage space: 3978
> unneeded,3222 used
> > [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is
> 360
> > [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 9
> > [0] Mat_CheckInode(): Found 120 nodes of 360. Limit used: 5. Using Inode
> routines
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> -2080374784
> -2080374784
> > Fatal error in PMPI_Bcast: Invalid communicator, error stack:
> > PMPI_Bcast(1478): MPI_Bcast(buf=0x7fff30dacecc, count=1, MPI_INT,
> root=0, comm=0x0) failed
> > PMPI_Bcast(1418): Invalid communicator
> > I inserted some print statement between the ksp calls and found that the
> error occurs in
> > call KSPSetFromOptions(ksp, pierr)
> > 2. If I change hmpi_spawn_size 3 to hmpi_merge_size 2 and launch my job
> by
>    How come there is no - in front of hmpi_merge_size 2?
>    Can you try putting all the arguments as command line arguments instead
> of in a file? It shouldn't matter but it seems like some of the arguments
> are being ignored.
>    Barry
> > mpiexec.mpich2 -n 2 myprogram
> > [0] petscinitialize_(): (Fortran):PETSc successfully started: procs 2
> gilbert.(none)
> > [1] petscinitialize_(): (Fortran):PETSc successfully started: procs 2
> > [1] PetscGetHostName(): Rejecting domainname, likely is NIS
> gilbert.(none)
> > [1] petscinitialize_(): Running on machine: gilbert
> -2080374780 max tags = 2147483647
> > [1] PetscCommDuplicate(): Duplicating a communicator 1140850688
> -2080374782 max tags = 2147483647
> > [0] PetscCommDuplicate(): Duplicating a communicator 1140850689
> -2080374777 max tags = 2147483647
> > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
> -2080374777
> > [1] PetscCommDuplicate(): Duplicating a communicator 1140850689
> > [1] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
> -2080374780
> > [0] MatStashScatterBegin_Private(): No of messages: 1
> > [0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 12896
> > [0] MatAssemblyBegin_MPIAIJ(): Stash has 1611 entries, uses 0 mallocs.
> > [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 180; storage space: 1998
> unneeded,1602 used
> 180
> > [0] Mat_CheckInode(): Found 60 nodes of 180. Limit used: 5. Using Inode
> routines
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 180; storage space: 1998
> unneeded,1602 used
> > [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is
> 180
> > [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 9
> > [1] Mat_CheckInode(): Found 60 nodes of 180. Limit used: 5. Using Inode
> routines
> -2080374777
> -2080374780
> -2080374777
> -2080374780
> > [0] VecScatterCreateCommon_PtoS(): Using blocksize 1 scatter
> > [0] VecScatterCreate(): General case: MPI to Seq
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 3; storage space: 396
> unneeded,9 used
> > [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 3
> > [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
> > [1] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> -2080374782
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 180 X 3; storage space: 396
> unneeded,9 used
> > [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 3
> > [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
> -2080374780
> > [0] VecAssemblyBegin_MPI(): Stash has 180 entries, uses 1 mallocs.
> > [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
> -2080374782
> -2080374780
> > [0] PCSetUp(): Setting up new PC
> -2080374780
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Nonconforming object sizes!
> > [0]PETSC ERROR: HMPI preconditioner only works for sequential solves!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29
> 11:26:24 CDT 2012
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ../../esd-tough2/xt2_eos4 on a arch-linu named gilbert
> by gpau Fri Aug 31 13:00:31 2012
> > [0]PETSC ERROR: Libraries linked from
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/lib
> > [0]PETSC ERROR: Configure run at Thu Aug 30 15:27:17 2012
> > [0]PETSC ERROR: Configure options --with-debugging=0
> --with-mpi-dir=/usr/lib/mpich2 --download-hypre=1
> --prefix=/home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: PCCreate_HMPI() line 283 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/impls/openmp/hpc.c
> > [0]PETSC ERROR: PCSetType() line 83 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/interface/pcset.c
> > [0]PETSC ERROR: PCSetFromOptions() line 188 in
> > [0]PETSC ERROR: KSPSetFromOptions() line 287 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itcl.c
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: PC does not have apply!
> > [0]PETSC ERROR:
> 11:26:24 CDT 2012
> > [0]PETSC ERROR:
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: PCApply() line 382 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: KSPInitialResidual() line 64 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itres.c
> > [0]PETSC ERROR: KSPSolve_GMRES() line 230 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/impls/gmres/gmres.c
> > [0]PETSC ERROR: KSPSolve() line 446 in
> /home/gpau/tough_codes/esd-tough2/build/Linux-x86_64-Debug-MPI-EOS4/toughlib/tpls/petsc/petsc-3.3-p3-source/src/ksp/ksp/interface/itfunc.c
> > I note that the error appears to occur at the same point.
> > George
> > On Fri, Aug 31, 2012 at 11:31 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > On Aug 31, 2012, at 1:27 PM, George Pau <gpau at lbl.gov> wrote:
> > > Hi Barry,
> > > 1. It is the exact same error related to MPI_ERR_COMM and MPI_Bcast.
> >    That should not happen. Please run and send all the output including
> the exact command line used
> > >  I am currently using the MPICH2 distribution provided by ubuntu but
> if MPICH version that Petsc download with -download-mpich works, I can use
> that.
> > > 2. If I use hmpi_merge_size, I will need to launch mpiexec with more
> than 1 cpus.  But, petsc will complain that the pctype hmpi can only be
> used in serial.
> >    That should not happen. Run with 2 MPI processes and -hmpi_merge_size
> 2  and send the complete error message.
> >   Barry
> > > George
> > > On Aug 31, 2012, at 11:17 AM, Barry Smith wrote:
> > >> On Aug 30, 2012, at 10:02 PM, George Pau <gpau at lbl.gov> wrote:
> > >>> Hi Barry,
> > >>> I tried with the addition of
> > >>> -hmpi_spawn_size 3
> > >>> but I am still getting the same error though.
> > >>   The EXACT same error? Or some other error?
> > >>    What happens if you run with the -hmpi_merge_size <size> option
> instead?
> > >>  Barry
> > >> 1) I am getting a crash with the spawn version I suspect is due to
> bugs in the MPICH version I am using related to spawn.
> > >> 2) I am getting errors with the merge version due to Apple's ASLR
> which they make hard to turn off.
> > >>> I am using mpich2.  Any other options to try?
> > >>> George
> > >>> On Aug 30, 2012, at 7:28 PM, Barry Smith wrote:
> > >>>> On Aug 30, 2012, at 7:24 PM, George Pau <gpau at lbl.gov> wrote:
> > >>>>> Hi,
> > >>>>> I have some issues using the -pctype hmpi.  I used the same
> setting found at
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHMPI.html
> > >>>>> i.e.
> > >>>>> -pc_type hmpi
> > >>>>> -ksp_type preonly
> > >>>>> -hmpi_ksp_type cg
> > >>>>> -hmpi_pc_type hypre
> > >>>>> My command  is
> > >>>>> mpiexec -n 1 myprogram
> > >>>> Sorry the documentation doesn't make this clearer. You need to
> start PETSc with special options to get the "worker" processes initialized.
> From the manual page for PCHMPI it has
> > >>>> See PetscHMPIMerge() and PetscHMPISpawn() for two ways to start up
> MPI for use with this preconditioner
> > >>>> This will tell you want option to start PETSc up with.
> > >>>> I will fix the PC so that it prints a far more useful error message.
> > >>>> Barry
> > >>>>> But, I get
> > >>>>> [gilbert:4041] *** An error occurred in MPI_Bcast
> > >>>>> [gilbert:4041] *** on communicator MPI_COMM_WORLD
> > >>>>> [gilbert:4041] *** MPI_ERR_COMM: invalid communicator
> > >>>>> [gilbert:4041] *** MPI_ERRORS_ARE_FATAL (your MPI job will now
> abort)
> > >>>>> with openmpi.  I get similar error with mpich2
> > >>>>> PMPI_Bcast(1478): MPI_Bcast(buf=0x7fffb683479c, count=1, MPI_INT,
> > >>>>> I couldn't figure out what is wrong.    My petsc is  version 3.3.3
> and the configuration is -with-debugging=0 --with-mpi-dir=/usr/lib/openmpi
> --download-hypre=1 and I am on a Ubuntu machine.
> > >>>>> Note that with the default pc_type and ksp_type, everything is
> fine.  It was also tested with multiple processors.  I wondering whether
> there are some options that I am not specifying correctly?
> > >>>>> George Pau
> > >>>>> Earth Sciences Division
> > >>>>> Lawrence Berkeley National Laboratory
> > >>>>> One Cyclotron, MS 74-120
> > >>>>> Berkeley, CA 94720
> > >>>>> (510) 486-7196
> > >>>>> gpau at lbl.gov
> > >>>>> http://esd.lbl.gov/about/staff/georgepau/
> > George Pau
> > Berkeley, CA 94720
> > (510) 486-7196
> > gpau at lbl.gov
George Pau
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120831/878b9d40/attachment-0001.html>
