[petsc-users] Hypre through Petsc: BoomerAMG options
Jed Brown
jedbrown at mcs.anl.gov
Wed Aug 29 10:08:30 CDT 2012
On Wed, Aug 29, 2012 at 9:59 AM, Arun Kamath <arun.kamath.m at gmail.com>wrote:
> Hei!
> I was going through the Petsc user archives when I came across a
> discussion with Barry Smith regarding use of BoomerAMG through Petsc
> (http://lists.mcs.anl.gov/pipermail/petsc-users/2006-October/000692.html).
> What I did understand from that is some of the Hypre options cannot
> be accessed through Petsc. But options like Pilut are available as
> preconditioners or solvers depnding on ksptype.
> I am trying to use ILU smoothening to BoomerAMG (Hypre's manual lists the
> smoothers available and the function calls).
HYPRE_BoomerAMGSetRelaxType, which is the relevant routine, does not
support ILU. Hypre does not have an extensible system for smoothing so you
can't add new smoothers without changing their library.
> The questions that remain after going through that discussion are:
> 1. Can a smoothening option in hypre's boomerAMG could be chosen at all
> using Petsc?
-pc_hypre_boomeramg_relax_type_all (or up/down)
> 2. Could the function calls phrases used in Hypre itself be somehow
> employed in the Petsc code?
I don't know what you are asking for.
> Would be really grateful for any advice. Since I am using an IDE to build
> the code, non-command line option tricks would also be of great help.
You can set command line options with PetscOptionsSetValue(), but this is a
slow way to experiment. I thought the purpose of an IDE was to make you
more productive. Recompiling every time you change the solver is a good way
to greatly reduce your productivity. Also, hard-coding configurations is a
good way to make your software less useful later.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120829/3cbdfba4/attachment-0001.html>
