[petsc-users] Scaling a vector with an entry from a DMRedundant
Barry Smith
bsmith at mcs.anl.gov
Tue Aug 21 13:22:37 CDT 2012
Send the source to ArcContShellMult to petsc-maint and we'll find you an alternative.
Barry
On Aug 21, 2012, at 11:45 AM, Kevin Green <kevin.richard.green at gmail.com> wrote:
> Hi all,
> I've created a Matshell multiplication that acts on a vector derived from a DMComposite which contains a DMDA and a DMRedundant of size 1 living on process 0. It does its job on a single process, but on multiple processes, the VecAXPY (see below) fails with the error:
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Scalar value must be same on all processes, argument # 2!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Development HG revision: 9cac76b7c349ad267a1605750f02b8ef9d350ff1 HG Date: Tue Aug 21 10:07:43 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex3 on a arch-linu named lester by kg Tue Aug 21 12:36:10 2012
> [0]PETSC ERROR: Libraries linked from /home/kg/lib/petsc-dev/arch-linux2-c-debug/lib
> [0]PETSC ERROR: Configure run at Tue Aug 21 11:54:03 2012
> [0]PETSC ERROR: Configure options PETSC_ARCH=arch-linux2-c-debug
> [0]PETSC ERROR: VecAXPY() line 550 in src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: ArcContShellMult() line 1049 in ex3.c
> [0]PETSC ERROR: MatMult() line 2146 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCApplyBAorAB() line 621 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPGMRESCycle() line 155 in src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve_GMRES() line 231 in src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve() line 446 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: main() line 425 in ex3.c
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 1.
> Prodding the Matshell shows that a process that the DMRedundant doesn't "live" on has size 0. I guess the behaviour I expected is that every process would have space for the redundant entry, but all processes would be synchronized with the process where it lives upon access (or at least on a scatter, broadcast, ... something).
> The examples with DMRedundant are cases where only a single process needs to know the "redundant" part (so why is that called redundant?), and do not demonstrate this behaviour.
> Do I have to broadcast the information myself before I can scale a global vector? Is there something that might work better than DMRedundant? Any suggestions would be welcome.
> Cheers,
> Kevin
> Matshell multiplication routine:
> ArcContShellMult - MatMult overload for linear system of a pseudo-arclength continuation
> [du_post;dlam_post] = [dFdu dFdlam; du0 dlam0]*[du;dlam]
> Input Parameters:
> . A - The matshell
> . x - the state to operate on
> Output Parameters:
> . y - the result
> PetscErrorCode ArcContShellMult(Mat A,Vec x,Vec y)
> PetscInt ierr;
> void *ctx;
> ArcContCtx *arc_ctx;
> Vec delta_U, delta_lam, delta_U_post, delta_lam_post;
> PetscScalar *del_lam_arr,lam_on_entry;
> PetscFunctionBegin;
> ierr = MatShellGetContext(A,&ctx); CHKERRQ(ierr);
> arc_ctx = (ArcContCtx*)(ctx);
> Get the components of the composite input and output
> ierr = DMCompositeGetAccess(arc_ctx->dmc,x,&delta_U,&delta_lam);CHKERRQ(ierr);
> ierr = DMCompositeGetAccess(arc_ctx->dmc,y,&delta_U_post,&delta_lam_post);CHKERRQ(ierr);
> Get lambda component as usable array
> ierr = VecGetArray(delta_lam,&del_lam_arr);CHKERRQ(ierr);
> lam_on_entry = del_lam_arr[0];
> Multiply and add each of the components
> ierr = MatMult(arc_ctx->dFdu,delta_U,delta_U_post);CHKERRQ(ierr);
> ierr = VecAXPY(delta_U_post,del_lam_arr[0],arc_ctx->dFdlam);CHKERRQ(ierr);
> ierr = VecDot(arc_ctx->du0,delta_U,&del_lam_arr[0]);CHKERRQ(ierr);
> del_lam_arr[0] += arc_ctx->dlam0*lam_on_entry;
> Gather components back to the y vector
> ierr = VecRestoreArray(delta_lam,&del_lam_arr);CHKERRQ(ierr);
> ierr = VecCopy(delta_lam,delta_lam_post);
> ierr = DMCompositeRestoreAccess(arc_ctx->dmc,x,&delta_U,&delta_lam);CHKERRQ(ierr);
> ierr = DMCompositeRestoreAccess(arc_ctx->dmc,y,&delta_U_post,&delta_lam_post);CHKERRQ(ierr);
> PetscFunctionReturn(0);
