[petsc-users] MatMatSolve in sequential call
Alexander Grayver
agrayver at gfz-potsdam.de
Tue Aug 21 11:25:36 CDT 2012
On 21.08.2012 18:14, Hong Zhang wrote:
> Alexander :
> Testing your matrix A.dat
> using petsc-3.3/src/ksp/ksp/examples/tutorials/ex10.c,
> I find that A is numerically singular:
Hong,
Sorry, but I forgot to mention that this is double complex symmetric
matrix. Did you load and treat it like that?
> I'm convinced that matrix A is corrupted or obtained from an incorrect
> numerical model.
> Also note, your matrix A has size of approx. 60k, which is too large
> for sequential direct solver.
MUMPS takes only several minutes and 6 GB of memory to factorize it.
This factorization gives residual on the order of 10e-12 and solution is
indeed correct.
Nevertheless, you're right, there is numerical null-space in this matrix
since it comes
from the discretization of equation that contains curl curl operator,
but practically this
case is not really the worst one.
> The error on MatMatSolve() when calling
> ' -pc_type cholesky -pc_factor_mat_solver_package mumps'
> is a bug in our petsc-mumps interface. I've pushed a fix to petsc-3.3
> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/8badc49a596e
> Thanks for your report.
Thank you for the patch.
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120821/1ead77ed/attachment-0001.html>
