[petsc-users] Field split questions
Mon Aug 20 10:09:15 CDT 2012
On Mon, Aug 20, 2012 at 7:47 AM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
> I am just not seeing where in the section such an IS would go. As far as I
> can tell from the functions in vsection.c, the only item in the section
> which is an IS is bcIndices, defining points where bcs are applied.
If you have no structure other than dof, you can make a Section where the
points
just number dofs. Then you just run through the ints p in your IS can call
  PetscSectionSetDof(section, p, 1)
Then PetscSectionSetUp(). Stick this in a DMSHELL, or really any DM you
want,
and FS will use it.
   Matt
>     38   ierr = PetscNew(struct _n_PetscSection, s);CHKERRQ(ierr);
>     39   (*s)->atlasLayout.comm   = comm;
>     40   (*s)->atlasLayout.pStart = -1;
>     41   (*s)->atlasLayout.pEnd   = -1;
>     42   (*s)->atlasLayout.numDof = 1;
>     43   (*s)->atlasDof           = PETSC_NULL;
>     44   (*s)->atlasOff           = PETSC_NULL;
>     45   (*s)->bc                 = PETSC_NULL;
>     46   (*s)->bcIndices          = PETSC_NULL;
>     47   (*s)->setup              = PETSC_FALSE;
>     48   (*s)->numFields          = 0;
>     49   (*s)->fieldNames         = PETSC_NULL;
>     50   (*s)->field              = PETSC_NULL;
> Quoting Matthew Knepley <knepley at gmail.com>:
>  On Mon, Aug 20, 2012 at 7:17 AM, Colin McAuliffe <cjm2176 at columbia.edu
>> >wrote:
>>  Yes, just call DMSetDefaultSection(). However, note that you will have
>>>> everything sized
>>>> correctly, but handling topology and iteration for the residual
>>>> calculation
>>>> would be completely
>>>> up to you.
>>>>    Matt
>>> It would be really great to define the initial data layout using IS to
>>> define the equation numbers of the splits, while letting the new DM stuff
>>> handle creating all the nested splits given command line options. Is
>>> something like this possible?
>> This is just what I say above. Is something not working?
>>    Matt
>>  Colin
>>>  On Mon, Aug 13, 2012 at 4:06 PM, Colin McAuliffe <cjm2176 at columbia.edu
>>>> >wrote:
>>>>  No, No, No. You do not have to write a DM implementation.
>>>>>> You just have to define the data layout in a PetscSection and attach
>>>>>> it
>>>>>> to
>>>>>> the DM with DMSetDefaultSection.
>>>>>>     Matt
>>>>>>  Does use of the PetscSection mean that it is neccesary to define a
>>>>> DMMesh?
>>>>> In other
>>>>> words is there a way to create the data layout for the physics without
>>>>> having to specify
>>>>> any information about the mesh?
>>>> everything sized
>>>> calculation
>>>> would be completely
>>>> up to you.
>>>>    Matt
>>>>  Thanks
>>>>> Colin
>>>>>  On Thu, Aug 9, 2012 at 10:22 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>
>>>>>  wrote:
>>>>>>  On Thu, Aug 9, 2012 at 10:02 AM, Colin McAuliffe  <
>>>>>>> >wrote:
>>>>>>>  Sanjay, thanks for the reply but I am avoiding using blocked format
>>>>>>>  since
>>>>>>>> my problem has 10 dofs per node but only has either dofs 1-3 or 4-10
>>>>>>>> active
>>>>>>>> on a particular node. If I use block the equations I run out of
>>>>>>>> memory
>>>>>>>> pretty quickly on my machine but can get to reasonable sized
>>>>>>>> problems
>>>>>>>> with
>>>>>>>> the unblocked format.
>>>>>>>> Matt, sorry I am not getting this, but I am still not sure how the
>>>>>>>> DM
>>>>>>>> interface works. I can see in the function PCFieldSplitSetDefaults
>>>>>>>> that
>>>>>>>> there is an initial call to DMCreateFieldDecomposition and
>>>>>>>> subsequent
>>>>>>>> calls
>>>>>>>> to DMCreateSubDM based on the command line options. What I am
>>>>>>>> missing
>>>>>>>> is
>>>>>>>> how the first call to DMCreateFieldDecomposition is able to figure
>>>>>>>> out
>>>>>>>> which equations belong to which field just from command line info
>>>>>>>> such
>>>>>>>> as
>>>>>>>> -pc_fieldsplit_0_fields 2,0. Where/how are the fields 2 and 0
>>>>>>>> defined?
>>>>>>>>  This might change slightly in the near future in petsc-dev to allow
>>>>>>>>  one to
>>>>>>> define splits using named fields.
>>>>>>> In any event, there has to be DM support to implement the
>>>>>>> decompositions
>>>>>>> over a particular mesh/problem over that mesh.
>>>>>>> With DMDA you can essentially get combinations of strided fields in
>>>>>>> each
>>>>>>> split. DMCOMPOSITE allows you
>>>>>>> to pull out combinations of the subproblems that were put in there to
>>>>>>> begin with. If you have your own mesh, you have to write
>>>>>>> a DM implementation around it to expose the available fields.
>>>>>> it
>>>>>> to
>>>>>>     Matt
>>>>>>  Dmitry.
>>>>>>>  Thanks
>>>>>>>> Colin
>>>>>>>>  On Thu, Aug 9, 2012 at 9:21 AM, Sanjay Govindjee <s_g at berkeley.edu
>>>>>>>>  wrote:
>>>>>>>>>  Colin,
>>>>>>>>>    I you block the equations in FEAP, then the restrained BCs are
>>>>>>>>>> 'included' in assembled PETSc matrix (these dofs have rows that
>>>>>>>>>> are
>>>>>>>>>> zero
>>>>>>>>>> modulo a value of unity on the diagonal and the restrained value
>>>>>>>>>> on
>>>>>>>>>> the
>>>>>>>>>> right-hand side).
>>>>>>>>>>  However, this is not necessary with the DM interface.
>>>>>>>>>    Matt
>>>>>>>>>  -sg
>>>>>>>>>  On 8/9/12 8:41 AM, Colin McAuliffe wrote:
>>>>>>>>>>  From what I can gather from the petsc-dev source it looks like
>>>>>>>>>> the
>>>>>>>>>>  commands in 4) will then generate the splits using strided
>>>>>>>>>> blocks.
>>>>>>>>>>> The
>>>>>>>>>>> problem with that is the fortran code I am using (FEAP) uses
>>>>>>>>>>> petsc
>>>>>>>>>>> to
>>>>>>>>>>> assemble and solve the linear problem within its own nonlinear
>>>>>>>>>>> and
>>>>>>>>>>> time
>>>>>>>>>>> stepping schemes. The linear problem that petsc solves already
>>>>>>>>>>> has
>>>>>>>>>>> boundary
>>>>>>>>>>> conditions applied to it so petsc only sees the active
>>>>>>>>>>> (unrestrained)
>>>>>>>>>>> equations. So then in general fields can't be extracted from the
>>>>>>>>>>> active
>>>>>>>>>>> equations using strided blocks and I am stuck with generating the
>>>>>>>>>>> index
>>>>>>>>>>> sets defining the splits on my own. Will it still be possible to
>>>>>>>>>>> make
>>>>>>>>>>> use
>>>>>>>>>>> of the new DM functions in this case?
>>>>>>>>>>> FEAP website:
>>>>>>>>>>> http://www.ce.berkeley.edu/**********projects/feap/<http://www.ce.berkeley.edu/********projects/feap/>
>>>>>>>>>>> <http://**www.ce.berkeley.edu/********projects/feap/<http://www.ce.berkeley.edu/******projects/feap/>
>>>>>>>>>>> <http://www.**ce.berkeley.edu/******projects/**feap/<http://ce.berkeley.edu/****projects/**feap/>
>>>>>>>>>>> <http://**www.ce.berkeley.edu/******projects/feap/<http://www.ce.berkeley.edu/****projects/feap/>
>>>>>>>>>>> <http://www.ce.**berkeley.edu/******projects/feap/<http://berkeley.edu/****projects/feap/>
>>>>>>>>>>> <http://**berkeley.edu/**projects/feap/<http://berkeley.edu/**projects/feap/>
>>>>>>>>>>> <http://www.**ce.berkeley.edu/****projects/**feap/<http://ce.berkeley.edu/**projects/**feap/>
>>>>>>>>>>> <http://www.**ce.berkeley.edu/**projects/**feap/<http://www.ce.berkeley.edu/**projects/feap/>
>>>>>>>>>>> <http://**berkeley.edu/**projects/feap/<http://berkeley.edu/projects/feap/>
>>>>>>>>>>> <http://**berkeley.edu/projects/feap/<http://berkeley.edu/projects/feap/>
>>>>>>>>>>> <http://www.ce.**berkeley.edu/****projects/feap/<http://berkeley.edu/**projects/feap/>
>>>>>>>>>>> <http://www.ce.**berkeley.edu/**projects/feap/<http://berkeley.edu/projects/feap/>
>>>>>>>>>>> <http://www.ce.**berkeley.edu/projects/feap/<http://www.ce.berkeley.edu/projects/feap/>
>>>>>>>>>>> Colin
>>>>>>>>>>>  On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <
>>>>>>>>>>>  wrote:
>>>>>>>>>>>>  On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe  <
>>>>>>>>>>>>  >wrote:
>>>>>>>>>>>>>  Thanks all, regarding use of DM in 3.3, is the procedure now
>>>>>>>>>>>>> to
>>>>>>>>>>>>> create
>>>>>>>>>>>>>  the fields with PCFieldSplitSetIS and then use
>>>>>>>>>>>>>  DMCreateFieldDecompositionDM
>>>>>>>>>>>>>> to create a new DM based from the new fields and the DM for
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> original
>>>>>>>>>>>>>> problem?
>>>>>>>>>>>>>>  1) Use petsc-dev
>>>>>>>>>>>>>>  2) PCFieldSplitSetIS() is independent. This allows you to
>>>>>>>>>>>>> define
>>>>>>>>>>>>> splits
>>>>>>>>>>>>> however you want, but then recursive gets harder
>>>>>>>>>>>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all
>>>>>>>>>>>>> fields
>>>>>>>>>>>>> apart at once
>>>>>>>>>>>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off
>>>>>>>>>>>>> any
>>>>>>>>>>>>> combination of fields, which from the command line is something
>>>>>>>>>>>>> like
>>>>>>>>>>>>>      -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>>>>>>>>>>>>>  I should have shown recursive:
>>>>>>>>>>>>>    -fieldsplit_0_pc_type fieldsplit
>>>>>>>>>>>> will split 2,0 into two blocks.
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>       Matt
>>>>>>>>>>>>   Colin
>>>>>>>>>>>>>> Colin McAuliffe
>>>>>>>>>>>>>> PhD Candidate
>>>>>>>>>>>>>> Columbia University
>>>>>>>>>>>>>> Department of Civil Engineering and Engineering Mechanics
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their
>>>>>>>>>>>>> experiments is infinitely more interesting than any results to
>>>>>>>>>>>>> which
>>>>>>>>>>>>> their
>>>>>>>>>>>>> experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>>> which
>>>>>>>>>>>> their
>>>>>>>>>>>> experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> Sanjay Govindjee, PhD, PE
>>>>>>>>>> Professor of Civil Engineering
>>>>>>>>>> Vice Chair for Academic Affairs
>>>>>>>>>> 779 Davis Hall
>>>>>>>>>> Structural Engineering, Mechanics and Materials
>>>>>>>>>> University of California
>>>>>>>>>> Berkeley, CA 94720-1710
>>>>>>>>>> Voice:  +1 510 642 6060
>>>>>>>>>> FAX:    +1 510 643 5264
>>>>>>>>>> s_g at berkeley.edu
>>>>>>>>>> http://www.ce.berkeley.edu/~**********sanjay<http://www.ce.berkeley.edu/~********sanjay>
>>>>>>>>>> <http://www.ce.**berkeley.edu/~******sanjay<http://www.ce.berkeley.edu/~******sanjay>
>>>>>>>>>> <http://www.ce.**berkeley.edu/**~****sanjay<http://berkeley.edu/~****sanjay>
>>>>>>>>>> <http://www.ce.**berkeley.edu/~****sanjay<http://www.ce.berkeley.edu/~****sanjay>
>>>>>>>>>> <http://www.ce.**berkeley.edu/****~**sanjay<http://berkeley.edu/**~**sanjay>
>>>>>>>>>> <http://berkeley.**edu/~**sanjay <http://berkeley.edu/~**sanjay>>
>>>>>>>>>> <http://www.ce.**berkeley.edu/**~**sanjay<http://berkeley.edu/~**sanjay>
>>>>>>>>>> <http://www.ce.**berkeley.edu/~**sanjay<http://www.ce.berkeley.edu/~**sanjay>
>>>>>>>>>> http://www.ce.berkeley.edu/~********sanjay<http://www.ce.berkeley.edu/~******sanjay>
>>>>>>>>>> <http://www.ce.berkeley.**edu/****~sanjay<http://www.ce.**
>>>>>>>>>> berkeley.edu/~sanjay <http://www.ce.berkeley.edu/~**sanjay<http://www.ce.berkeley.edu/~sanjay>
>>>>>>>>> which
>>>>>>>>> their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> Colin McAuliffe
>>>>>>>> PhD Candidate
>>>>>>>> Columbia University
>>>>>> experiments is infinitely more interesting than any results to which
>>>>>> their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Colin McAuliffe
>>>>> PhD Candidate
>>>>> Columbia University
>>>> their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Colin McAuliffe
>>> PhD Candidate
>>> Columbia University
>> experiments lead.
>> -- Norbert Wiener
> Colin McAuliffe
> PhD Candidate
> Columbia University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120820/92a342d4/attachment-0001.html>
