[petsc-users] Field split questions
Colin McAuliffe cjm2176 at columbia.edu
Mon Aug 20 07:47:12 CDT 2012
I am just not seeing where in the section such an IS would go. As far
as I can tell from the functions in vsection.c, the only item in the
section which is an IS is bcIndices, defining points where bcs are
applied.
     38   ierr = PetscNew(struct _n_PetscSection, s);CHKERRQ(ierr);
     39   (*s)->atlasLayout.comm   = comm;
     40   (*s)->atlasLayout.pStart = -1;
     41   (*s)->atlasLayout.pEnd   = -1;
     42   (*s)->atlasLayout.numDof = 1;
     43   (*s)->atlasDof           = PETSC_NULL;
     44   (*s)->atlasOff           = PETSC_NULL;
     45   (*s)->bc                 = PETSC_NULL;
     46   (*s)->bcIndices          = PETSC_NULL;
     47   (*s)->setup              = PETSC_FALSE;
     48   (*s)->numFields          = 0;
     49   (*s)->fieldNames         = PETSC_NULL;
     50   (*s)->field              = PETSC_NULL;
Quoting Matthew Knepley <knepley at gmail.com>:
> On Mon, Aug 20, 2012 at 7:17 AM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
>> Yes, just call DMSetDefaultSection(). However, note that you will have
>>> everything sized
>>> correctly, but handling topology and iteration for the residual
>>> calculation
>>> would be completely
>>> up to you.
>>>    Matt
>> It would be really great to define the initial data layout using IS to
>> define the equation numbers of the splits, while letting the new DM stuff
>> handle creating all the nested splits given command line options. Is
>> something like this possible?
> This is just what I say above. Is something not working?
>    Matt
>> Colin
>>  On Mon, Aug 13, 2012 at 4:06 PM, Colin McAuliffe <cjm2176 at columbia.edu
>>> >wrote:
>>>  No, No, No. You do not have to write a DM implementation.
>>>>> You just have to define the data layout in a PetscSection and attach it
>>>>> to
>>>>> the DM with DMSetDefaultSection.
>>>>>     Matt
>>>> Does use of the PetscSection mean that it is neccesary to define a
>>>> DMMesh?
>>>> In other
>>>> words is there a way to create the data layout for the physics without
>>>> having to specify
>>>> any information about the mesh?
>>> everything sized
>>> calculation
>>> would be completely
>>> up to you.
>>>    Matt
>>>  Thanks
>>>> Colin
>>>>  On Thu, Aug 9, 2012 at 10:22 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>
>>>>> wrote:
>>>>>> On Thu, Aug 9, 2012 at 10:02 AM, Colin McAuliffe  <
>>>>>> >wrote:
>>>>>>  Sanjay, thanks for the reply but I am avoiding using blocked format
>>>>>>> since
>>>>>>> my problem has 10 dofs per node but only has either dofs 1-3 or 4-10
>>>>>>> active
>>>>>>> on a particular node. If I use block the equations I run out of memory
>>>>>>> pretty quickly on my machine but can get to reasonable sized problems
>>>>>>> with
>>>>>>> the unblocked format.
>>>>>>> Matt, sorry I am not getting this, but I am still not sure how the DM
>>>>>>> interface works. I can see in the function PCFieldSplitSetDefaults
>>>>>>> that
>>>>>>> there is an initial call to DMCreateFieldDecomposition and subsequent
>>>>>>> calls
>>>>>>> to DMCreateSubDM based on the command line options. What I am missing
>>>>>>> is
>>>>>>> how the first call to DMCreateFieldDecomposition is able to figure out
>>>>>>> which equations belong to which field just from command line info such
>>>>>>> as
>>>>>>> -pc_fieldsplit_0_fields 2,0. Where/how are the fields 2 and 0 defined?
>>>>>>>  This might change slightly in the near future in petsc-dev to allow
>>>>>> one to
>>>>>> define splits using named fields.
>>>>>> In any event, there has to be DM support to implement the
>>>>>> decompositions
>>>>>> over a particular mesh/problem over that mesh.
>>>>>> With DMDA you can essentially get combinations of strided fields in
>>>>>> each
>>>>>> split. DMCOMPOSITE allows you
>>>>>> to pull out combinations of the subproblems that were put in there to
>>>>>> begin with. If you have your own mesh, you have to write
>>>>>> a DM implementation around it to expose the available fields.
>>>>> to
>>>>>     Matt
>>>>>  Dmitry.
>>>>>>  Thanks
>>>>>>> Colin
>>>>>>>  On Thu, Aug 9, 2012 at 9:21 AM, Sanjay Govindjee <s_g at berkeley.edu>
>>>>>>>  wrote:
>>>>>>>>  Colin,
>>>>>>>>    I you block the equations in FEAP, then the restrained BCs are
>>>>>>>>> 'included' in assembled PETSc matrix (these dofs have rows that are
>>>>>>>>> zero
>>>>>>>>> modulo a value of unity on the diagonal and the restrained value on
>>>>>>>>> the
>>>>>>>>> right-hand side).
>>>>>>>>>  However, this is not necessary with the DM interface.
>>>>>>>>    Matt
>>>>>>>>  -sg
>>>>>>>>> On 8/9/12 8:41 AM, Colin McAuliffe wrote:
>>>>>>>>>  From what I can gather from the petsc-dev source it looks like the
>>>>>>>>>  commands in 4) will then generate the splits using strided blocks.
>>>>>>>>>> The
>>>>>>>>>> problem with that is the fortran code I am using (FEAP) uses petsc
>>>>>>>>>> to
>>>>>>>>>> assemble and solve the linear problem within its own nonlinear and
>>>>>>>>>> time
>>>>>>>>>> stepping schemes. The linear problem that petsc solves already has
>>>>>>>>>> boundary
>>>>>>>>>> conditions applied to it so petsc only sees the active
>>>>>>>>>> (unrestrained)
>>>>>>>>>> equations. So then in general fields can't be extracted from the
>>>>>>>>>> active
>>>>>>>>>> equations using strided blocks and I am stuck with generating the
>>>>>>>>>> index
>>>>>>>>>> sets defining the splits on my own. Will it still be possible to
>>>>>>>>>> make
>>>>>>>>>> use
>>>>>>>>>> of the new DM functions in this case?
>>>>>>>>>> FEAP website:
>>>>>>>>>> http://www.ce.berkeley.edu/********projects/feap/<http://www.ce.berkeley.edu/******projects/feap/>
>>>>>>>>>> <http://www.**ce.berkeley.edu/****projects/**feap/<http://www.ce.berkeley.edu/****projects/feap/>
>>>>>>>>>> <http://www.ce.**berkeley.edu/****projects/feap/<http://berkeley.edu/**projects/feap/>
>>>>>>>>>> <http://www.**ce.berkeley.edu/**projects/**feap/<http://www.ce.berkeley.edu/**projects/feap/>
>>>>>>>>>> <http://**berkeley.edu/projects/feap/<http://berkeley.edu/projects/feap/>
>>>>>>>>>> <http://www.ce.**berkeley.edu/**projects/feap/<http://berkeley.edu/projects/feap/>
>>>>>>>>>> <http://www.ce.**berkeley.edu/projects/feap/<http://www.ce.berkeley.edu/projects/feap/>
>>>>>>>>>> Colin
>>>>>>>>>>  On Wed, Aug 8, 2012 at 10:51 PM, Matthew Knepley <
>>>>>>>>>>  wrote:
>>>>>>>>>>>  On Wed, Aug 8, 2012 at 10:23 PM, Colin McAuliffe  <
>>>>>>>>>>>  >wrote:
>>>>>>>>>>>>  Thanks all, regarding use of DM in 3.3, is the procedure now to
>>>>>>>>>>>> create
>>>>>>>>>>>>  the fields with PCFieldSplitSetIS and then use
>>>>>>>>>>>>> DMCreateFieldDecompositionDM
>>>>>>>>>>>>> to create a new DM based from the new fields and the DM for the
>>>>>>>>>>>>> original
>>>>>>>>>>>>> problem?
>>>>>>>>>>>>>  1) Use petsc-dev
>>>>>>>>>>>> 2) PCFieldSplitSetIS() is independent. This allows you to define
>>>>>>>>>>>> splits
>>>>>>>>>>>> however you want, but then recursive gets harder
>>>>>>>>>>>> 3) In 3.3., it uses DMCreateFieldDecompositionDM() to split all
>>>>>>>>>>>> fields
>>>>>>>>>>>> apart at once
>>>>>>>>>>>> 4) In petsc-dev, it uses DMCreateSubDM() which can split off any
>>>>>>>>>>>> combination of fields, which from the command line is something
>>>>>>>>>>>> like
>>>>>>>>>>>>      -pc_fieldsplit_0_fields 2,0 -pc_fieldsplit_1_fields 1,3
>>>>>>>>>>>>  I should have shown recursive:
>>>>>>>>>>>   -fieldsplit_0_pc_type fieldsplit
>>>>>>>>>>> will split 2,0 into two blocks.
>>>>>>>>>>>    Matt
>>>>>>>>>>>       Matt
>>>>>>>>>>>>  Colin
>>>>>>>>>>>>> Colin McAuliffe
>>>>>>>>>>>>> PhD Candidate
>>>>>>>>>>>>> Columbia University
>>>>>>>>>>>>> Department of Civil Engineering and Engineering Mechanics
>>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>>> experiments is infinitely more interesting than any results to
>>>>>>>>>>>> which
>>>>>>>>>>>> their
>>>>>>>>>>>> experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> which
>>>>>>>>>>> their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> Sanjay Govindjee, PhD, PE
>>>>>>>>> Professor of Civil Engineering
>>>>>>>>> Vice Chair for Academic Affairs
>>>>>>>>> 779 Davis Hall
>>>>>>>>> Structural Engineering, Mechanics and Materials
>>>>>>>>> University of California
>>>>>>>>> Berkeley, CA 94720-1710
>>>>>>>>> Voice:  +1 510 642 6060
>>>>>>>>> FAX:    +1 510 643 5264
>>>>>>>>> s_g at berkeley.edu
>>>>>>>>> http://www.ce.berkeley.edu/~********sanjay<http://www.ce.berkeley.edu/~******sanjay>
>>>>>>>>> <http://www.ce.**berkeley.edu/~****sanjay<http://www.ce.berkeley.edu/~****sanjay>
>>>>>>>>> <http://www.ce.**berkeley.edu/**~**sanjay<http://berkeley.edu/~**sanjay>
>>>>>>>>> <http://www.ce.**berkeley.edu/~**sanjay<http://www.ce.berkeley.edu/~**sanjay>
>>>>>>>>> http://www.ce.berkeley.edu/~******sanjay<http://www.ce.berkeley.edu/~****sanjay>
>>>>>>>>> <http://www.ce.berkeley.**edu/**~sanjay<http://www.ce.**
>>>>>>>>> berkeley.edu/~sanjay <http://www.ce.berkeley.edu/~sanjay>>
>>>>>>>> experiments is infinitely more interesting than any results to which
>>>>>>>> their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> Colin McAuliffe
>>>>>>> PhD Candidate
>>>>>>> Columbia University
>>>>> their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Colin McAuliffe
>>>> PhD Candidate
>>>> Columbia University
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
> experiments lead.
> -- Norbert Wiener
Colin McAuliffe
PhD Candidate
Columbia University
