[petsc-users] Nullspace for a coupled system of equations
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Fri Aug 17 14:06:01 CDT 2012
Am 17.08.2012 16:24, schrieb Matthew Knepley:
> On Fri, Aug 17, 2012 at 3:10 AM, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
> I want to solve some (weakly) coupled system of equations of the
> following form:
> A B u
> 0 C v
> so, C is the discrete Laplacian and A and B are some more
> complicated operators (I make use of linear finite elements). All
> boundary conditions are periodic, so the unknown v is determined
> only up to a constant. A and B contain both the identity operator,
> so u is fixed. Now I want to solve the system on the whole (there
> are reasons to do it in this way!) and I must provide information
> about the nullspace to the solver. When I am right, to provide the
> correct nullspace I must solve one equation with A. Is there any
> way in PETSc to circumvent the problem?
> If I understand you correctly, your null space vector is (0 I). I use
> the same null space for SNES ex62.
(0 I) cannot be an element of the null space, as multiplying it with the
matrix results in a non-zero vector. Or am I totally wrong about null
spaces of matrices?
Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/0b3e8a00/attachment.html>
