[petsc-users] Segmentation fault when using matlab interface
Jed Brown
jedbrown at mcs.anl.gov
Fri Aug 17 06:43:31 CDT 2012
Can you set up a stand-alone test case that exhibits the error?
On Fri, Aug 17, 2012 at 2:25 AM, De Groof, Vincent <
Vincent.De-Groof at uibk.ac.at> wrote:
> Hello,
> I'm trying to use the Petsc objects directly from Matlab. However, when
> testing the examples in the
> /bin/matlab/classes/examples/tutorials-directory, I get a segmentation
> fault (core dump) error. Unfortunately, I don't get more information then
> this. After running some different situations, I know the following:
> I ran matlab both with and without desktop. The only error message I get
> is the segmentation fault. Sometimes it doesn't give the segmentation error
> after running the example. If so, it will cause a segmentation fault upon
> entering the next command in the matlab shell. If I quit matlab immediately
> after running an example without segmentation fault, my unix shell will
> hang.
> I know it's kind of vague, but this is all I know now. Any suggestions to
> look at to solve this problem?
> thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120817/bca266d4/attachment.html>
