[petsc-users] petsc building error on mac 10.8
Kyunghoon Lee
aeronova.mailing at gmail.com
Tue Aug 14 06:26:30 CDT 2012
Thank you for the suggestion; I'll send my log file to
petsc-maint at mcs.anl.gov.
K. Lee.
On Mon, Aug 13, 2012 at 10:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> For these problems you NEED to send the entire configure.log file to
> petsc-maint at mcs.anl.gov There is no way we can guess the problem with
> this little information.
> Barry
> On Aug 13, 2012, at 9:09 AM, Kyunghoon Lee <aeronova.mailing at gmail.com>
> wrote:
> > Hi all,
> > I got the following error when I try to build petsc on mac os x 10.8
> (mountain lion) --- it failed at MPICH:
> > Configuring PETSc to compile on your system
> > ***** WARNING: CC found in enviornment variables - ignoring ******
> > ***** WARNING: CXX found in enviornment variables - ignoring ******
> > Running configure on MPICH; this may take several minutes
> > Running make on MPICH; this may take several minutes
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> > Error running make; make install on MPICH: Could not execute "cd
> /Users/aeronova/Development/local/share/petsc/3.3-p2/externalpackages/mpich2-1.4.1p1
> && make && make install":
> > Beginning make
> > Make completed
> > Remove
> /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib/libmpich.dylib
> and rerun make install
> > Remove
> /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib/libpmpich.dylib
> > libtool: install: warning: remember to run `libtool --finish
> /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib'
> > make: *** [install-preamble] Error 1
> > This error is confusing since there are a bunch of warnings without an
> error message. My configuration options are
> > ./configure
> --prefix=/Users/aeronova/Development/local/lib/petsc/3.3-p2-real
> --download-mpich=1 --download-blacs=1 --download-metis=1
> --download-parmetis=1 --download-scalapack=1 --download-mumps=1
> --download-umfpack=1 --with-clanguage=C++
> > I'd appreciate it if anyone can help me with this error.
> > Regards,
> > K. Lee.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120814/f03b62ff/attachment.html>
