[petsc-users] petsc building error on mac 10.8
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 13 09:33:39 CDT 2012
For these problems you NEED to send the entire configure.log file to petsc-maint at mcs.anl.gov There is no way we can guess the problem with this little information.
Barry
On Aug 13, 2012, at 9:09 AM, Kyunghoon Lee <aeronova.mailing at gmail.com> wrote:
> Hi all,
> I got the following error when I try to build petsc on mac os x 10.8 (mountain lion) --- it failed at MPICH:
> Configuring PETSc to compile on your system
> ***** WARNING: CC found in enviornment variables - ignoring ****** =============================================================================== ===============================================================================
> ***** WARNING: CXX found in enviornment variables - ignoring ****** =============================================================================== ===============================================================================
> Running configure on MPICH; this may take several minutes =============================================================================== ===============================================================================
> Running make on MPICH; this may take several minutes =============================================================================== *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Error running make; make install on MPICH: Could not execute "cd /Users/aeronova/Development/local/share/petsc/3.3-p2/externalpackages/mpich2-1.4.1p1 && make && make install":
> Beginning make
> Make completed
> Remove /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib/libmpich.dylib and rerun make install
> Remove /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib/libpmpich.dylib and rerun make install
> libtool: install: warning: remember to run `libtool --finish /Users/aeronova/Development/local/share/petsc/3.3-p2/arch-darwin-cxx-debug-real/lib'
> make: *** [install-preamble] Error 1
> This error is confusing since there are a bunch of warnings without an error message. My configuration options are
> ./configure --prefix=/Users/aeronova/Development/local/lib/petsc/3.3-p2-real --download-mpich=1 --download-blacs=1 --download-metis=1 --download-parmetis=1 --download-scalapack=1 --download-mumps=1 --download-umfpack=1 --with-clanguage=C++
> I'd appreciate it if anyone can help me with this error.
> Regards,
> K. Lee.
