[petsc-users] Configure error
Fri Aug 10 10:35:59 CDT 2012
On Fri, Aug 10, 2012 at 10:34 AM, Fabio <fabio.pinna.2006 at gmail.com> wrote:
> 2012/8/10 Satish Balay <balay at mcs.anl.gov>:
> > Executing: /cygdrive/d/Workspace/PETSc/petsc-3.3-p2/bin/win32fe/win32fe
> cl  -o /tmp/petsc-_yEt5c/config.setCompilers/conftest.exe
>  /tmp/petsc-_yEt5c/config.setCompilers/conftest.o
> > sh: LINK : fatal error LNK1104: cannot open file 'kernel32.lib'^M
> > Ok configure failing with compiler check. It hasn't gone up to mpi check.
> > Have you setup compilers in bash correctly [as the installation
> > instructions indicate?]. Have you checked if the compiler works [in
> > both 'compiler cmd' as well as bash] with a simple code - as the
> >> MSVC Express (32 bit with some work to do to make it see 64 bit by
> >> means of sdk installation)?
> > I don't know what you mean by this.
> > Using 32bit compilers on 64bit windows shouldn't be a problem. You
> > shouldn't need 'some work' to have useable 32bit compilers.
> > Satish
> > On Fri, 10 Aug 2012, Fabio wrote:
> >> Without using the wiht-mpi-dir option the code start testing but it
> >> stops saying the "C compiler associated with mpi-cc win32fe cl  does
> >> not work"
> >> (configure.log is its log)
> >> If I use a link to another directory without space in the name I get
> >> the same error (provided that the link has been done in cygwin
> >> otherwise I have Nonexistant directory). It seems than anyway path are
> >> an issue in general (although for standard path they seem to find
> >> correctly what they need)
> >> The respective log file is configure2.log
> >> It look like it is not finding kernel32.lib. Actually a search in my
> >> system find only kernel32.dll so I think that the configure script
> >> complain rightfully.
> >> Anyway could this be linked to my setup win 7 64 bit and MSVC Express
> >> (32 bit with some work to do to make it see 64 bit by means of sdk
> >> installation)?
> >>  I thought I could just start with a 32 bit version as it is the
> >> default setting of MSVC and it was quite hard to make the 64 bit work
> >> (I would have liked to have something simple to focus only on my real
> >> implementation, instead of running after VC Express tantrums)
> >> Thank you very much for your assistance
> >> Fabio
> >> >> I updated to the last version of Petsc then I used again
> >> >> PETSC_DIR=`pwd`; export PETSC_DIR
> >> >> then in the petsc directory
> >> >> ./configure --with-cc='win32fe cl' --with-fc=0
> >> >> --download-f2cblas-lapack --with-mpi-dir=/cygdrive/c/Program\ Files\
> >> >> \(x86\)/MPICH2
> >> >> Now I have an error,
> >> >> "Nonexistent directory /cygdrive/c/Program\ Files\ \(x86\)/MPICH2"
> >> >> The directory anyway is there and cygwin could easily access it
> >> >> Also trying with mpi-include/lib gives the same error.
> >> >> What can I do?
> >> > Remove the --with-mpi-dir option.
> >> > Configure should automatically look for mpich at this location.
> >> > Satish
> I start from the VC prompt and then I go to cygwin. When I type cl
> under cygwin I have the message
> Microsoft (R) 32-bit C/C++Optimizing Compiler Version ... so I believe
> cl is really working.
> Is there something more I could do (in the mean whiel I will write a
> simple program to test the compiler)?
You need to try and compile something. We can execute the compiler, but it
cannot find its libraries.
   Matt
> Fabio
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120810/44b6676e/attachment.html>
