[petsc-users] Configure error
Fabio
fabio.pinna.2006 at gmail.com
Fri Aug 10 10:34:38 CDT 2012
2012/8/10 Satish Balay <balay at mcs.anl.gov>:
> Executing: /cygdrive/d/Workspace/PETSc/petsc-3.3-p2/bin/win32fe/win32fe cl -o /tmp/petsc-_yEt5c/config.setCompilers/conftest.exe /tmp/petsc-_yEt5c/config.setCompilers/conftest.o
> sh: LINK : fatal error LNK1104: cannot open file 'kernel32.lib'^M
> Ok configure failing with compiler check. It hasn't gone up to mpi check.
> Have you setup compilers in bash correctly [as the installation
> instructions indicate?]. Have you checked if the compiler works [in
> both 'compiler cmd' as well as bash] with a simple code - as the
>> MSVC Express (32 bit with some work to do to make it see 64 bit by
>> means of sdk installation)?
> I don't know what you mean by this.
> Using 32bit compilers on 64bit windows shouldn't be a problem. You
> shouldn't need 'some work' to have useable 32bit compilers.
> Satish
> On Fri, 10 Aug 2012, Fabio wrote:
>> Without using the wiht-mpi-dir option the code start testing but it
>> stops saying the "C compiler associated with mpi-cc win32fe cl does
>> not work"
>> (configure.log is its log)
>> If I use a link to another directory without space in the name I get
>> the same error (provided that the link has been done in cygwin
>> otherwise I have Nonexistant directory). It seems than anyway path are
>> an issue in general (although for standard path they seem to find
>> correctly what they need)
>> The respective log file is configure2.log
>> It look like it is not finding kernel32.lib. Actually a search in my
>> system find only kernel32.dll so I think that the configure script
>> complain rightfully.
>> Anyway could this be linked to my setup win 7 64 bit and MSVC Express
>> (32 bit with some work to do to make it see 64 bit by means of sdk
>> installation)?
>> I thought I could just start with a 32 bit version as it is the
>> default setting of MSVC and it was quite hard to make the 64 bit work
>> (I would have liked to have something simple to focus only on my real
>> implementation, instead of running after VC Express tantrums)
>> Thank you very much for your assistance
>> Fabio
>> >> I updated to the last version of Petsc then I used again
>> >> PETSC_DIR=`pwd`; export PETSC_DIR
>> >> then in the petsc directory
>> >> ./configure --with-cc='win32fe cl' --with-fc=0
>> >> --download-f2cblas-lapack --with-mpi-dir=/cygdrive/c/Program\ Files\
>> >> \(x86\)/MPICH2
>> >> Now I have an error,
>> >> "Nonexistent directory /cygdrive/c/Program\ Files\ \(x86\)/MPICH2"
>> >> The directory anyway is there and cygwin could easily access it
>> >> Also trying with mpi-include/lib gives the same error.
>> >> What can I do?
>> > Remove the --with-mpi-dir option.
>> > Configure should automatically look for mpich at this location.
>> > Satish
I start from the VC prompt and then I go to cygwin. When I type cl
under cygwin I have the message
Microsoft (R) 32-bit C/C++Optimizing Compiler Version ... so I believe
cl is really working.
Is there something more I could do (in the mean whiel I will write a
simple program to test the compiler)?
Fabio
