[petsc-users] Customizeing MatSetValuesBlocked(...)
Hong Zhang hzhang at mcs.anl.gov
Wed Aug 8 20:02:21 CDT 2012
Jinquan:
Has this problem or similar problem been solved using scalapack?
Your problem is virtually a dense problem, why choose petsc library?
What type of computer, number of cores, to be used for this problem?
Hong
 First question:****
> Are your matrices sparse or dense?****
> **·         **A is a dense matrix at the order of 225,000 of complex*16;
> How large? ****
> **·         **800GB on disk****
> What type of math equations, e.g., solve Ax=b or eigenvalue problems?****
> **·         **A’x=b, where A’=[A^-1 U B]= sparse matrix at the order of 2
> million.  B = sparse matrix to be mixed and mingled with A^-1.****
> Hong****
> Jinquan****
> On Wed, Aug 8, 2012 at 5:36 PM, Jinquan Zhong <jzhong at scsolutions.com>
> wrote:****
> Thanks, Prof. Zhang.****
> I could have used PETSc directly for this application. However, I have to
> use this procedure for QA (quality assurance) purposes since this
> parallelizing process for a program I am working on is a standard program
> widely used in industry.  That is, QA purposes have driven us to use
> ScaLAPACK for inversion first then PETSc for solution.  I wish I could a
> big move now to eliminate ScaLAPACK.****
> Jinquan****
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Hong Zhang
> *Sent:* Wednesday, August 08, 2012 3:29 PM****
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] Customizeing MatSetValuesBlocked(...)****
> Jinquan:****
> You need understand some basic concepts in numerical computations, for
> example:****
> - dense matrix vs. sparse matrix and their data structures****
> - algorithms for solve Ax=b****
> - available software packages, their targeted applications****
> See www.mcs.anl.gov/~hzhang/teach/cs595 for a list of references.****
> Hong****
>  What I am trying to say is that ****
> ·         allocated 1D array A in PETSc****
> ·         passed 1D A into ScaLAPACK****
> ·         obtained the indices of A^-1 computed from ScaLAPACK and stored
> them in a 1D array****
> ·         indexed A^-1 as a 1D array in PETSc using the indices obtained
> from ScaLAPACK****
> ·         constructed a sparse matrix, including A^-1 and others, using a
> new set of indices for A^-1.  ****
> I can have  the last step done in using ****
>                        ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>                        ierr =
> MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);CHKERRQ(ierr);****
>                        ierr = MatSetFromOptions(A);CHKERRQ(ierr);****
>                        ierr = MatSetUp(A);CHKERRQ(ierr);****
>   ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);****
> It just took too long.  This is the performance issue I am having.  ****
> To improve the performance, it is necessary for preallocation.  The
> dilemma is: *MatCreateAIJ* and *MatXCreateAIJ* complained the setting of *d_nz,
> d_nnz,o_nz, o_nnz*  since there are no diagonal and off-diagonal parts
> defined in A^-1.****
> Jinquan****
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* Wednesday, August 08, 2012 3:04 PM****
> On Wed, Aug 8, 2012 at 3:45 PM, Jinquan Zhong <jzhong at scsolutions.com>
> wrote:****
> It is a 1D matrix in PETSc.  I just passed it as a 2D matrix in
> ScaLAPACK.  It is still a 1D matrix when get back into PETSc.****
> What are you trying to say?****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/29ea0b98/attachment.html>
