[petsc-users] Field split questions
Colin McAuliffe
cjm2176 at columbia.edu
Wed Aug 8 19:54:55 CDT 2012
Thanks I will look into DM. Is PCFieldSplitGetSubKSP in petsc version
3.1p8 callable from fortran? I am getting the following error when I
compile the fortran code, and I cant figure out if this is an error in
my code or what.
Undefined symbols for architecture x86_64:
"_pcfieldsplitgetsubksp_", referenced from:
_umacr6_ in umacr6.o
ld: symbol(s) not found for architecture x86_64
thanks
Colin
Quoting Matthew Knepley <knepley at gmail.com>:
> On Wed, Aug 8, 2012 at 8:48 AM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
>> Hello all,
>> When using PCFieldSplitSetIS to define splits within splits, should the IS
>> contain indices in the original matrix or in the next highest split level?
> The next highest split level. You might consider using a DM if you have
> some structure (like discretization on a mesh).
> This should handle all the index-wrangling for you. It is new, but intended
> for just this kind of thing.
> Also, my matrix is in aij format but one of the sub fields has a block
>> diagonal structure. Is it still possible use block jacobi on this field?
> Yes.
> Matt
>> Thanks and all the best
>> Colin
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
>> Department of Civil Engineering and Engineering Mechanics
> experiments lead.
> -- Norbert Wiener
Colin McAuliffe
PhD Candidate
Columbia University
