[petsc-users] Field split questions
Matthew Knepley
knepley at gmail.com
Wed Aug 8 08:52:12 CDT 2012
On Wed, Aug 8, 2012 at 8:48 AM, Colin McAuliffe <cjm2176 at columbia.edu>wrote:
> Hello all,
> When using PCFieldSplitSetIS to define splits within splits, should the IS
> contain indices in the original matrix or in the next highest split level?
The next highest split level. You might consider using a DM if you have
some structure (like discretization on a mesh).
This should handle all the index-wrangling for you. It is new, but intended
for just this kind of thing.
Also, my matrix is in aij format but one of the sub fields has a block
> diagonal structure. Is it still possible use block jacobi on this field?
Yes.
Matt
> Thanks and all the best
> Colin
> Colin McAuliffe
> PhD Candidate
> Columbia University
> Department of Civil Engineering and Engineering Mechanics
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/33ff26f7/attachment.html>
