[petsc-users] return -1 instead of raising an error in ao.app2petsc
Xin Zhao
sean.null at gmail.com
Wed Aug 8 16:22:26 CDT 2012
if (low > high) {ia[i] = -1;continue;}
On Wed, Aug 8, 2012 at 10:18 PM, Xin Zhao <sean.null at gmail.com> wrote:
> PetscErrorCode AOApplicationToPetsc_Mapping(AO ao, PetscInt n, PetscInt
> *ia)
> has
> if (low > high) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_ARG_OUTOFRANGE,
> "Invalid input index %D", idex);
> Well.... is it a good idea to rewrite this part as
> if (low > high) ia[i] = -1;
> And wait for comments from PETSc developers?
> Need I recompile petsc4py after compiling PETSc?
> Best,
> Xin
> On Wed, Aug 8, 2012 at 9:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Hmm,
>> PetscErrorCode AOApplicationToPetsc_Basic(AO ao,PetscInt n,PetscInt *ia)
>> has
>> if (ia[i] >= 0 && ia[i] < N) {
>> ia[i] = aobasic->petsc[ia[i]];
>> } else {
>> ia[i] = -1;
>> *ia)
>> has
>> PetscErrorCode AOApplicationToPetsc_MemoryScalable(AO ao,PetscInt
>> n,PetscInt *ia)
>> has
>> if (ia[i] >= owners[rank] && ia[i] < owners[rank+1] ) {
>> ia[i] = maploc[ia[i]-owners[rank]];
>> } else {
>> ia[i] = -1 ; /* ia[i] is not in the range of 0 and N-1, maps it
>> to -1 */
>> So it seems the intention is to return -1 for out of range not an error.
>> Can the PETSc developer who wrote all this stuff comment? Likely our
>> bug! Also we should fix the manual page for AOApplicationToPetsc() to
>> clearly indicate what happens for out of range values
>> Barry
>> On Aug 8, 2012, at 3:10 PM, Xin Zhao <sean.null at gmail.com> wrote:
>> > Dear all,
>> > Assume that I want to convert an indices in application order into
>> petsc order.
>> > But I don't know the indices in application is in range.
>> > Say
>> > I call
>> > ao = PETSc.AO().createMapping([4,2,3])
>> > then
>> > ao.app2petsc([2,5,3])
>> > will raise an error.
>> > is there any way to make return value to [1,-1,2] instead of raising an
>> error?
>> > Or there is any way I can handle this error to make it work?
>> > Best,
>> > Xin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/613996d6/attachment.html>
