[petsc-users] return -1 instead of raising an error in ao.app2petsc
Xin Zhao
sean.null at gmail.com
Wed Aug 8 16:18:47 CDT 2012
PetscErrorCode AOApplicationToPetsc_Mapping(AO ao, PetscInt n, PetscInt *ia)
has
if (low > high) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_ARG_OUTOFRANGE,
"Invalid input index %D", idex);
Well.... is it a good idea to rewrite this part as
if (low > high) ia[i] = -1;
And wait for comments from PETSc developers?
Need I recompile petsc4py after compiling PETSc?
Best,
Xin
On Wed, Aug 8, 2012 at 9:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Hmm,
> PetscErrorCode AOApplicationToPetsc_Basic(AO ao,PetscInt n,PetscInt *ia)
> has
> if (ia[i] >= 0 && ia[i] < N) {
> ia[i] = aobasic->petsc[ia[i]];
> } else {
> ia[i] = -1;
> *ia)
> has
> PetscErrorCode AOApplicationToPetsc_MemoryScalable(AO ao,PetscInt
> n,PetscInt *ia)
> has
> if (ia[i] >= owners[rank] && ia[i] < owners[rank+1] ) {
> ia[i] = maploc[ia[i]-owners[rank]];
> } else {
> ia[i] = -1 ; /* ia[i] is not in the range of 0 and N-1, maps it to
> -1 */
> So it seems the intention is to return -1 for out of range not an error.
> Can the PETSc developer who wrote all this stuff comment? Likely our
> bug! Also we should fix the manual page for AOApplicationToPetsc() to
> clearly indicate what happens for out of range values
> Barry
> On Aug 8, 2012, at 3:10 PM, Xin Zhao <sean.null at gmail.com> wrote:
> > Dear all,
> > Assume that I want to convert an indices in application order into petsc
> order.
> > But I don't know the indices in application is in range.
> > Say
> > I call
> > ao = PETSc.AO().createMapping([4,2,3])
> > then
> > ao.app2petsc([2,5,3])
> > will raise an error.
> > is there any way to make return value to [1,-1,2] instead of raising an
> error?
> > Or there is any way I can handle this error to make it work?
> > Best,
> > Xin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120808/a6375c66/attachment-0001.html>
