[petsc-users] Customizeing MatSetValuesBlocked(...)
Satish Balay
balay at mcs.anl.gov
Wed Aug 8 15:45:29 CDT 2012
On Wed, 8 Aug 2012, Jed Brown wrote:
> On Wed, Aug 8, 2012 at 2:25 PM, Jinquan Zhong <jzhong at scsolutions.com>wrote:
> > If I understand you correctly, ScaLAPACK blocks don't have anything to do
> > with the sparse matrix structure.****
> > You are correct. What I meant was how to define the diagonal and
> > off-diagonal parts of each submatrix matrix A (LDA, LDB). For example, in
> > the following matrix,****
> > *Proc0* *Proc1* *Proc2*****
> > 1 2 0 | 0 3 0 | 0 4****
> > *Proc0* 0 5 6 | 7 0 0 | 8 0****
> > 9 0 10 | 11 0 0 | 12 0****
> > 13 0 14 | 15 16 17 | 0 0****
> > *Proc3* 0 18 0 | 19 20 21 | 0 0 <=== owned by Proc 5****
> > 0 0 0 | 22 23 0 | 24 0****
> > *Proc6* 25 26 27 | 0 0 28 | 29 0****
> > 30 0 0 | 31 32 33 | 0 34****
> > I am not sure how to fill out the values for d_nz, d_nnz,o_nz, o_nnz
> > peoperly for the subblock (0 0 ;0 0; 24 0) owned by Proc 5 since it was
> > based on diagonal and off-diagonal parts.
> Throw your 2D block cyclic nonsense out the window. These are sparse
> matrices and that layout would be terrible. Logically permute your matrices
> all you want, then define a global ordering and chunk it into contiguous
> blocks of rows (no partition of columns). Work this out with a pencil and
> paper. You should have a function that translates row/column pairs from
> your ordering to our ordering. Now compute the sparsity pattern in the new
> ordering. (Usually you can figure this out on paper as well.) Then
> preallocate and call MatSetValues() with the new (row,column) locations.
also check the 'example usage' at:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateAIJ.html
Satish
