[petsc-users] Configure error
Fabio fabio.pinna.2006 at gmail.com
Sun Aug 5 17:19:25 CDT 2012
Thank you for your quick reply,I will try with a reboot.
Regarding the compiler my idea was to use MSVC express 2008. I thought
it was possible to compile both library with gcc under cygwin.
>From your reply I guess this is not the case.
Does this mean I should compile Petsc with MSVC express as well, isn't it?
Fabio.
2012/8/5 Satish Balay <balay at mcs.anl.gov>:
> On Sun, 5 Aug 2012, Fabio wrote:
>> Dear all,
>> I am new to petsc, and I've been struggling with it for the last days.
>> I want to install it on Windows 7, and first  I tried to install the
>> Microsoft MPI and then compiling the MPICH. They both seems ok but I
>> am not able to compile Petsc with any of them.
>> I am mostly interested to MPICH (for portability).
>> I used this script to configure
>> ./config/configure.py PETSC_ARCH=win32-gnu  --with-fc=0
>> --download-f2cblaslapack=1
>> –with-mpi-dir=/cygdrive/d/Workspace/MPICH/mpich2-1.4.1p1
> What compilers do you plan to use? MS C/C++ or cygwin gcc/g++?
> [MS MPI is for use with MS compiler only. MPICH binary install is for
> MS compilers, and MPICH source install is for cygwin gcc/g++]
>>  and I've got this error,
>>                     UNABLE to EXECUTE BINARIES for config/configure.py
>> [Errno 16] Device or resource busy: 'conftest.exe'
>> This error seems to happen pretty randomly at differente places in the script.
>> Any idea to solve this problem?
> Its bad file locks on windows. The only suggestion we have is reboot.
> For some cygwin issues - you need to run 'rebaseall' but this doesn;t apper to be
> that issue.
> If you still have issues - send the complete log [and logfile] to petsc-maint.
> Satish
>> Thank you all
>> Fabio
