[petsc-users] with hypre
Amneet Bhalla mail2amneet at gmail.com
Fri Aug 3 08:12:28 CDT 2012
Thanks Matt for a quick reply.
Attached is the Makefile I used for building ex9. I used the same Makefile
provided by  hypre. I just changed the
path of hypre's directory. Also attached is the command and full output I
got. Using the same Makefile I was able to
build and run ex1, ex2, ex3 and ex4 of hypre.
Can you point me to PETSc's examples of AMG, ML or GAMG?
On Fri, Aug 3, 2012 at 7:47 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 3, 2012 at 7:28 AM, Amneet Bhalla <mail2amneet at gmail.com>wrote:
>> Hi All,
>> I am trying to solve system of PDEs on AMR grid. I using PETSc 's Krylov
>> solver for that. This requires me
>> to use a FAC preconditioner with a non-Krylov solver for the level 0. I
>> actually tried PETSc's Krylov Solver
>> for level 0 (by building  MPIAIJ Mat and Vec), but it does not really
>> improve the convergence rate. So I believe
>> I will have to use a multigrid solver for level 0. Can I use my already
>> built PETSc Mat and Vec and call multigrid solvers from PETSc?
> Use AMG to start here since it is easy. You can either use ML or GAMG
> (which is builtin) to start, or Hypre if
> you straighten out the link (likely broken from not using the makefiles).
>> If thats not possible, I am planning to use hypre's "SysPFMG" to write a
>> I have installed PETSc with hypre by using --download-hypre=1 option.  I
>> can build and run many
>> examples in PETSC_ARCH/externalpackages/hypre-2.7.0b/src/examples/ but
>> not ex9; which is the
>> closest I could find for my purpose.
>> http://acts.nersc.gov/hypre/example09/ex9.c.html
>>  I am getting some linkage error like
> Always send the entire output, including the command that was run. I have
> no idea what file you are trying to
> compile here. Does the example work?
>    Matt
>> $HOME/SOFTWARES/LIBRARIES/PETSc/linux/lib/libHYPRE.a(par_gsmg.o): In
>> function `hypre_BoomerAMGFitVectors':
>> $HOME/SOFTWARES/LIBRARIES/PETSc/externalpackages/hypre-2.7.0b/src/parcsr_ls/par_gsmg.c:735:
>> undefined reference to `dgels_'
>> $HOME/SOFTWARES/LIBRARIES/PETSc/linux/lib/libHYPRE.a(par_relax.o): In
>> function `hypre_BoomerAMGRelax':
>> $HOME/SOFTWARES/LIBRARIES/PETSc/externalpackages/hypre-2.7.0b/src/parcsr_ls/par_relax.c:3135:
>> undefined reference to `dgetrf_'
>> $HOME/SOFTWARES/LIBRARIES/PETSc/externalpackages/hypre-2.7.0b/src/parcsr_ls/par_relax.c:3146:
>> undefined reference to `dgetrs_'
>> $HOME/SOFTWARES/LIBRARIES/PETSc/linux/lib/libHYPRE.a(schwarz.o): In
>> function `hypre_AMGNodalSchwarzSmoother':
>> $HOME/SOFTWARES/LIBRARIES/PETSc/externalpackages/hypre-2.7.0b/src/parcsr_ls/schwarz.c:312:
>> undefined reference to `dpotrf_'
>> Any help will be appreciated.
>> Thanks,
>> Amneet
> experiments lead.
> -- Norbert Wiener
Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/66d427da/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/66d427da/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120803/66d427da/attachment-0001.obj>
