[petsc-users] error in petsc-dev
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Tue Apr 24 18:27:25 CDT 2012
Thanks Hong.
On Tue, Apr 24, 2012 at 4:25 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> See
> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html:
> You MUST now call MatXXXSetPreallocation() or MatSetUp() on any matrix you
> create directly (not using DMCreateMatrix()) before calling MatSetValues(),
> MatSetValuesBlocked() etc.
> On Tue, Apr 24, 2012 at 6:01 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> Hi,
>> While trying to figure out a problem, I came across the following
>> situation. Consider the following code:
>> int main (int argc, char **argv){
>>     PetscInitialize(&argc, &argv, (char*)0, help);
>>     Mat m;
>>     MatCreate(PETSC_COMM_WORLD, &m);
>>     MatSetSizes(m, 10, 10, PETSC_DECIDE, PETSC_DECIDE);
>>     MatSetFromOptions(m);
>>     MatAssemblyBegin(m, MAT_FINAL_ASSEMBLY);
>>     MatAssemblyEnd(m, MAT_FINAL_ASSEMBLY);
>>     MatView(m, PETSC_VIEWER_STDOUT_WORLD);
>>     MatDestroy(&m);
>>     PetscFinalize();
>>     return 0;
>> This runs without any problem under 3.2-p6 but fails with petsc-dev:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state!
>> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
>> argument 1 "mat" before MatAssemblyBegin()!
>> [0]PETSC ERROR:
>> Eventually I could fix this by adding MatSetUp(m) after setting the
>> options. Why do I need this in petsc-dev? Does this somehow preallocate the
>> matrix?
> Yes.
> Hong
>> Thanks,
>> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/9a1919e2/attachment.htm>
