[petsc-users] error in petsc-dev
Hong Zhang hzhang at mcs.anl.gov
Tue Apr 24 18:25:14 CDT 2012
See
http://www.mcs.anl.gov/petsc/documentation/changes/dev.html:
You MUST now call MatXXXSetPreallocation() or MatSetUp() on any matrix you
create directly (not using DMCreateMatrix()) before calling MatSetValues(),
MatSetValuesBlocked() etc.
On Tue, Apr 24, 2012 at 6:01 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Hi,
> While trying to figure out a problem, I came across the following
> situation. Consider the following code:
> int main (int argc, char **argv){
>     PetscInitialize(&argc, &argv, (char*)0, help);
>     Mat m;
>     MatCreate(PETSC_COMM_WORLD, &m);
>     MatSetSizes(m, 10, 10, PETSC_DECIDE, PETSC_DECIDE);
>     MatSetFromOptions(m);
>     MatAssemblyBegin(m, MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(m, MAT_FINAL_ASSEMBLY);
>     MatView(m, PETSC_VIEWER_STDOUT_WORLD);
>     MatDestroy(&m);
>     PetscFinalize();
>     return 0;
> This runs without any problem under 3.2-p6 but fails with petsc-dev:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatAssemblyBegin()!
> [0]PETSC ERROR:
> Eventually I could fix this by adding MatSetUp(m) after setting the
> options. Why do I need this in petsc-dev? Does this somehow preallocate the
> matrix?
Yes.
Hong
> Thanks,
> Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/5fe51ea2/attachment.htm>
