[petsc-users] Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Tue Apr 24 15:32:13 CDT 2012
I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from c to fortran
version. The fortran version is based on the template of ex22f, which is
in 3d.
I have attached the code below. I have 2 problems.
1. When i3 = -3, in dirichlet BC, I got the same answer as ex29 in c
version.
However, when I change i3 to -4, I got the following error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
fc934c1d84bc6ba8e2686702a8a99539d
50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a petsc-3.2 named
USER-PC by
  User Tue Apr 24 22:08:46 2012
[0]PETSC ERROR: Libraries linked from
/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
/lib
[0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
[0]PETSC ERROR: Configure options --with-cc="win32fe cl"
--with-fc="win32fe ifor
t" --with-cxx="win32fe cl" --with-mpi-dir=/cygdrive/d/Lib/MPICH2/
--download-f-b
las-lapack=1 --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
--with-debuggin
g=1 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
src/mat/impls/aij/seq/C:\temp\
PETSC-~1\src\mat\impls\aij\seq\aij.c
[0]PETSC ERROR: MatSetValues() line 1148 in
src/mat/interface/C:\temp\PETSC-~1\s
rc\mat\INTERF~1\matrix.c
[0]PETSC ERROR: MatSetValuesLocal() line 2003 in
-~1\src\mat\INTERF~1\matrix.c
[0]PETSC ERROR: MatSetValuesStencil() line 1379 in
SC-~1\src\mat\INTERF~1\matrix.c
[0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
What did I do wrong?
2. When I wanted to use the neumann BC, following ex29, I added :
In subroutine ComputeRHS
call
MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
call MatNullSpaceDestroy(nullspace,ierr)
and in subroutine ComputeMatrix
call
call MatSetNullSpace(jac,nullspace,ierr)
When I compile, it says unresolved external symbol MatNullSpaceRemove.
Removing MatNullSpaceRemove, I can compile but running gives the error:
[0]PETSC ERROR: Corrupt argument:
see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
[0]PETSC ERROR: Invalid Pointer to Object: Parameter # 4!
[0]PETSC ERROR:
[0]PETSC ERROR:
USER-PC by
  User Tue Apr 24 22:30:31 2012
/lib
--download-f-b
--with-debuggin
g=1 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatNullSpaceCreate() line 250 in
-~1\src\mat\INTERF~1\matnull.c
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR:
[0]PETSC ERROR:
USER-PC by
/lib
--download-f-b
--with-debuggin
g=1 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
C-~1\src\mat\INTERF~1\matnull.c
[0]PETSC ERROR: ourdmfunction() line 30 in
src/dm/interface/ftn-custom/C:\temp\P
ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
[0]PETSC ERROR: DMComputeFunction() line 1783 in
src/dm/interface/C:\temp\PETSC-
~1\src\dm\INTERF~1\dm.c
[0]PETSC ERROR: KSPSetUp() line 218 in
src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
c\ksp\ksp\INTERF~1\itfunc.c
[0]PETSC ERROR:
[0]PETSC ERROR:
USER-PC by
/lib
--download-f-b
--with-debuggin
g=1 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR:
USER-PC by
/lib
--download-f-b
--with-debuggin
g=1 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR: KSPSolve() line 402 in
Vector Object:Vec_0000000084000000_0 1 MPI processes
   type: mpi
Process [0]
What's wrong?
*program ex29f*
implicit none
!                    Include files
!     petscsys.h  - base PETSc routines      petscvec.h - vectors
!     petscmat.h - matrices
!     petscksp.h    - Krylov subspace methods  petscpc.h  - preconditioners
#include "finclude/petsc.h90"
PetscErrorCode   ierr
DM               da
KSP              ksp
Vec              x
external         ComputeRHS,ComputeMatrix
PetscInt i1,i3
call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
i3 = -4
i1 = 1
call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
call
DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
call DMSetFunction(da,ComputeRHS,ierr)
call DMSetJacobian(da,ComputeMatrix,ierr)
call KSPSetDM(ksp,da,ierr)
call KSPSetFromOptions(ksp,ierr)
call KSPSetUp(ksp,ierr)
call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
call KSPGetSolution(ksp,x,ierr)
call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
call KSPDestroy(ksp,ierr)
call DMDestroy(da,ierr)
call PetscFinalize(ierr)
end program ex29f
subroutine ComputeRHS(da,x,b,ierr)
implicit none
PetscErrorCode  ierr
PetscInt i,j,mx,my,xm,ym,xs,ys
PetscScalar  h,nu,rho
PetscScalar Hx,Hy
PetscScalar,pointer :: array(:,:)
Vec          x,b
DM           da
MatNullSpace nullspace    !>neumann BC
nu = 0.1
call
DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
Hx = 1.d0 / (mx-1)
Hy = 1.d0 / (my-1)
call
DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
call DMDAVecGetArrayF90(da,b,array,ierr)
do j = ys,ys+ym-1
     do i = xs,xs+xm-1
         array(i,j) = exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
     end do
end do
call DMDAVecRestoreArrayF90(da,b,array,ierr)
call VecAssemblyBegin(b,ierr)
call VecAssemblyEnd(b,ierr)
!call
!call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
!call MatNullSpaceDestroy(nullspace,ierr)
end subroutine ComputeRHS
subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
implicit none
Mat          jac,JJ
PetscErrorCode    ierr
DM           da
PetscInt    i,j,k,mx,my,xm
PetscInt    ym,xs,ys,i1,i5
PetscScalar  v(5),Hx,Hy,rho,centerRho
PetscScalar  HydHx
PetscScalar  HxdHy
MatStencil   row(4),col(4,5)
Vec          x
MatStructure str
rho = 1.0
i1 = 1
i5 = 5
centerRho = rho
call
Hx = 1.d0 / (mx-1)
Hy = 1.d0 / (my-1)
HxdHy = Hx/Hy
HydHx = Hy/Hx
call
do j=ys,ys+ym-1
     do i=xs,xs+xm-1
         row(MatStencil_i) = i
         row(MatStencil_j) = j
         call ComputeRho(i,j,mx,my,centerRho,rho)
         if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or. j.eq.my-1) then
             v(1) = 2.0*rho*(HxdHy + HydHx)
             call
MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
         else
             v(1) = -rho*HxdHy
             col(MatStencil_i,1) = i
             col(MatStencil_j,2) = j-1
             v(2) = -rho*HydHx
             col(MatStencil_i,2) = i-1
             v(3) = 2.0*rho*(HxdHy + HydHx)
             col(MatStencil_i,3) = i
             col(MatStencil_j,3) = j
             v(4) = -rho*HydHx
             col(MatStencil_i,4) = i+1
             col(MatStencil_j,4) = j
             v(5) = -rho*HxdHy
             col(MatStencil_i,5) = i
             col(MatStencil_j,5) = j+1
             call
MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
         end if
     end do
end do
call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
!call
!call MatSetNullSpace(jac,nullspace,ierr)
end subroutine ComputeMatrix
subroutine ComputeRho(i,j,mx,my,centerRho,rho)
PetscInt    i,j,mx,my
PetscScalar  rho,centerRho
if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j > my/3.0) .and. (j <
2.0*my/3.0)) then
     rho = centerRho
else
     rho = 1.0
end if
end subroutine ComputeRho
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120424/c24ed305/attachment.htm>
