[petsc-users] A problem with MPI Derived Data Type and 'calloc'
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Thu Apr 19 09:52:04 CDT 2012
Thank you so much, Dr. Knepley.
Alan
On 4/19/2012 9:51 AM, Matthew Knepley wrote:
> On Thu, Apr 19, 2012 at 10:49 AM, Zhenglun (Alan) Wei
> <zhenglun.wei at gmail.com <mailto:zhenglun.wei at gmail.com>> wrote:
>     Dear Dr. Knepley,
>          It is very nice to hear that. I will read the manual. Do we
>     have any examples showing its functions?
> Lots of examples. Start with SNES ex5 and ex19.
>    Matt
>     thank you so much,
>     Alan
>     On 4/19/2012 9:35 AM, Matthew Knepley wrote:
>>     On Thu, Apr 19, 2012 at 10:18 AM, Zhenglun (Alan) Wei
>>             TESTVAR ***a, ***b, ***c;
>>             TESTVAR **aa, **bb, **cc;
>>             TESTVAR *arraya, *arrayb, *arrayc;
>>             arraya = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>>             arrayb = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>>             arrayc = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>>             aa =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>>             bb =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>>             cc =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>>             for(i = 0; i < SIZE*SIZE; i++) {
>>               aa[i] = &arraya[i*SIZE];
>>               bb[i] = &arrayb[i*SIZE];
>>               cc[i] = &arrayc[i*SIZE];
>>             a =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>>             b =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>>             c =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>>             for(i = 0; i < SIZE; i++) {
>>               a[i] = &aa[i*SIZE];
>>               b[i] = &bb[i*SIZE];
>>               c[i] = &cc[i*SIZE];
>>           It works. However, I wonder if there is any other good
>>         ideas for 3D problem other than this kinda of 'two-layer'
>>         approach.
>>         *_What is the reason for not using DMDA?_
>>         *In 2D, I established a 2D array for data communication
>>         between nodes by using MPI derived data type. It allows me to
>>         easily communicate both contiguous (i.e. MPI_TYPE_CONTIGUOUS)
>>         and non-contiguous (i.e. MPI_TYPE_VECTOR) data. That is why I
>>         use this similar approach in 3D, though an additional data
>>         type, i.e. MPI_TYPE_INDEXED, need to be used. Does DMDA have
>>         those type of function or derived data type?
>>     It definitely does communication between the local pieces. Do you
>>     want something else?
>>             "2, I have a little question on PETSc about 3D processor
>>             ordering. Does PETSc have any function giving me the
>>             nodes/rank number of neighboring nodes/ranks? Are those
>>             'Application Ordering' functions applicable for my case?"
>>         _*What do you mean by neighboring? If it is jsut stencil
>>         neighbors, then use a local vector.*_
>>         When I send and receive data with MPI_Send and MPI_RECV, I
>>         need provide the 'destination' (in MPI_Send refer
>>         to'http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Send.html')
>>         and 'source' (in MPI_RECV refer
>>         to'http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Recv.html').
>>         In a 2D problem with Cartesian grid, 4 processes divide the
>>         whole domain to 4 sub-domain.
>>               2      |      3      |
>>               0      |      1      |
>>          Then, for node 1, the neighboring nodes are '0' and '3',
>>         which '0' is the left node and '3' is the top node. I wonder
>>         if PETSc has any function that I can call to obtain those
>>         neighboring nodes so that I do not need to construct my
>>         function.
>>     Yes, it looks like you should just use a DMDA. See the manual
>>     section.
>>        Matt
>>         I'm sorry for confusing you.
>>         thanks in advance,
>>         Alan
>>         On 4/19/2012 4:52 AM, Matthew Knepley wrote:
>>>         On Wed, Apr 18, 2012 at 3:52 PM, Alan Wei
>>>             Dear all,
>>>                 I hope you're having a nice day. I have a further
>>>             question on this issue in 3D.
>>>             1, Following the idea of Dr. Brown and Dr. Knepley, I
>>>             finished a 2D test, which works very fine. Here, I did
>>>             it in 3D by
>>>             sizeof(TESTVAR));
>>>             sizeof(TESTVAR));
>>>             sizeof(TESTVAR));
>>>                   a[i] = &aa[i*SIZE];
>>>                   b[i] = &bb[i*SIZE];
>>>                   c[i] = &cc[i*SIZE];
>>>             'two-layer' approach.
>>>            Matt
>>>             thanks,
>>>             Alan
>>>             On Fri, Apr 13, 2012 at 5:41 PM, Jed Brown
>>>             <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>> wrote:
>>>                 On Fri, Apr 13, 2012 at 17:38, Zhenglun (Alan) Wei
>>>                         I have a final question on it. Is it taken a
>>>                     lot of memory for doing this? As I understand,
>>>                     pointers won't occupy many memories and it works
>>>                     like an alias. It will not, to my limit
>>>                     knowledge, take much extra memory by doing this.
>>>                 A pointer takes about as much space as a floating
>>>                 point value, so that array of pointers costs about
>>>                 1*N compared to the N*N matrix.
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120419/66877bae/attachment.htm>
