[petsc-users] A problem with MPI Derived Data Type and 'calloc'
Matthew Knepley
knepley at gmail.com
Thu Apr 19 09:51:07 CDT 2012
On Thu, Apr 19, 2012 at 10:49 AM, Zhenglun (Alan) Wei <
zhenglun.wei at gmail.com> wrote:
> Dear Dr. Knepley,
> It is very nice to hear that. I will read the manual. Do we have any
> examples showing its functions?
Lots of examples. Start with SNES ex5 and ex19.
Matt
> thank you so much,
> Alan
> On 4/19/2012 9:35 AM, Matthew Knepley wrote:
> On Thu, Apr 19, 2012 at 10:18 AM, Zhenglun (Alan) Wei <
>> TESTVAR ***a, ***b, ***c;
>> TESTVAR **aa, **bb, **cc;
>> TESTVAR *arraya, *arrayb, *arrayc;
>> arraya = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>> arrayb = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>> arrayc = (TESTVAR*) calloc(SIZE*SIZE*SIZE, sizeof(TESTVAR));
>> aa =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>> bb =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>> cc =(TESTVAR**) calloc(SIZE*SIZE, sizeof(TESTVAR*));
>> for(i = 0; i < SIZE*SIZE; i++) {
>> aa[i] = &arraya[i*SIZE];
>> bb[i] = &arrayb[i*SIZE];
>> cc[i] = &arrayc[i*SIZE];
>> a =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>> b =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>> c =(TESTVAR***) calloc(SIZE*SIZE, sizeof(TESTVAR**));
>> for(i = 0; i < SIZE; i++) {
>> a[i] = &aa[i*SIZE];
>> b[i] = &bb[i*SIZE];
>> c[i] = &cc[i*SIZE];
>> It works. However, I wonder if there is any other good ideas for 3D
>> problem other than this kinda of 'two-layer' approach.
>> *What is the reason for not using DMDA?
>> *In 2D, I established a 2D array for data communication between nodes by
>> using MPI derived data type. It allows me to easily communicate both
>> contiguous (i.e. MPI_TYPE_CONTIGUOUS) and non-contiguous (i.e.
>> MPI_TYPE_VECTOR) data. That is why I use this similar approach in 3D,
>> though an additional data type, i.e. MPI_TYPE_INDEXED, need to be used.
>> Does DMDA have those type of function or derived data type?
> It definitely does communication between the local pieces. Do you want
> something else?
>> "2, I have a little question on PETSc about 3D processor ordering.
>>> Does PETSc have any function giving me the nodes/rank number of neighboring
>>> nodes/ranks? Are those 'Application Ordering' functions applicable for my
>>> case?"
>> *What do you mean by neighboring? If it is jsut stencil neighbors, then
>> use a local vector.*
>> When I send and receive data with MPI_Send and MPI_RECV, I need provide
>> the 'destination' (in MPI_Send refer to'
>> http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Send.html')
>> and 'source' (in MPI_RECV refer to'
>> http://www.mcs.anl.gov/research/projects/mpi/www/www3/MPI_Recv.html').
>> In a 2D problem with Cartesian grid, 4 processes divide the whole domain to
>> 4 sub-domain.
>> 2 | 3 |
>> 0 | 1 |
>> Then, for node 1, the neighboring nodes are '0' and '3', which '0' is
>> the left node and '3' is the top node. I wonder if PETSc has any function
>> that I can call to obtain those neighboring nodes so that I do not need to
>> construct my function.
> Yes, it looks like you should just use a DMDA. See the manual section.
> Matt
>> I'm sorry for confusing you.
>> thanks in advance,
>> Alan
>> On 4/19/2012 4:52 AM, Matthew Knepley wrote:
>> On Wed, Apr 18, 2012 at 3:52 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
>>> Dear all,
>>> I hope you're having a nice day. I have a further question on this
>>> issue in 3D.
>>> 1, Following the idea of Dr. Brown and Dr. Knepley, I finished a 2D
>>> test, which works very fine. Here, I did it in 3D by
>>> a[i] = &aa[i*SIZE];
>>> b[i] = &bb[i*SIZE];
>>> c[i] = &cc[i*SIZE];
>>> 2, I have a little question on PETSc about 3D processor ordering. Does
>>> case?
>> use a local vector.
>> Matt
>>> thanks,
>>> Alan
>>> On Fri, Apr 13, 2012 at 5:41 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> On Fri, Apr 13, 2012 at 17:38, Zhenglun (Alan) Wei <
>>>>> I have a final question on it. Is it taken a lot of memory for
>>>>> doing this? As I understand, pointers won't occupy many memories and it
>>>>> works like an alias. It will not, to my limit knowledge, take much extra
>>>>> memory by doing this.
>>>> A pointer takes about as much space as a floating point value, so
>>>> that array of pointers costs about 1*N compared to the N*N matrix.
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120419/acf3560b/attachment-0001.htm>
