[petsc-users] Problem with "likely location of problem given in stack below"?
Zhenglun (Alan) Wei
zhenglun.wei at gmail.com
Mon Apr 9 16:13:46 CDT 2012
Thank you, Dr. Brown, for pointing me out this example. However, I met a
problem when I was trying to modify it.
I added a 'OutputFunction' subroutine to access the solution data
by using DMDAGetVecArray. I tried it with single process, it keeps
giving me this error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Object: Parameter # 1!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
85e6055943e0711fccdec2d08caeba48971d3d55 HG Date: Fri Sep 23 14:46:14
2011 -0700
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex45 on a arch-linu named l2118a-linux.soecs.ku.edu by
zlwei Mon Apr 9 17:11:02 2012
[0]PETSC ERROR: Libraries linked from
/home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Sep 23 17:13:32 2011
[0]PETSC ERROR: Configure options --download-f-blas-lapack=1
--download-mpich=1 --with-cc=gcc --with-fc=gfortran
PETSC_ARCH=arch-linux2-c-debug
[0]PETSC ERROR:
[0]PETSC ERROR: DMDAVecGetArray() line 51 in src/dm/impls/da/dagetarray.c
My code is attached.
thanks in advance,
Alan
On 4/7/2012 5:30 PM, Jed Brown wrote:
> On Sat, Apr 7, 2012 at 17:28, Jed Brown <jedbrown at mcs.anl.gov
> <mailto:jedbrown at mcs.anl.gov>> wrote:
> On Sat, Apr 7, 2012 at 17:18, Alan Wei <zhenglun.wei at gmail.com
> <mailto:zhenglun.wei at gmail.com>> wrote:
> Thanks Dr. Brown,
> It works. I made a wrong comment command so that the code
> did not go through the compilation. So it gives the same error
> message since I ran the old version of execution file.
> BTW, this ex29.c is a solver for 2D poisson equation. I
> wonder if there is any 3D Poisson Equation solver in PETSc code?
> http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex45.c.html
> I also see that your petsc-dev is from several months ago, you may
> want to update because the interface has been simplified slightly (the
> old thing still works, but this is somewhat simpler).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120409/ba444170/attachment.htm>
Laplacian in 3D. Modeled by the partial differential equation
- Laplacian u = 1,0 < x,y,z < 1,
with boundary conditions
u = 1 for x = 0, x = 1, y = 0, y = 1, z = 0, z = 1.
This uses multigrid to solve the linear system
The same as ex22.c except it does not use DMMG, it uses its replacement.
See src/snes/examples/tutorials/ex50.c
Can also be run with -pc_type exotic -ksp_type fgmres
static char help[] = "Solves 3D Laplacian using multigrid.\n\n";
#include <petscksp.h>
#include <petscdmda.h>
extern PetscErrorCode ComputeMatrix(DM,Vec,Mat,Mat,MatStructure*);
extern PetscErrorCode ComputeRHS(DM,Vec,Vec);
extern PetscErrorCode ComputeInitialGuess(DM,Vec);
extern PetscErrorCode OutputFunction(DM, Vec);
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
PetscErrorCode ierr;
KSP ksp;
PetscReal norm;
DM da;
Vec x,b,r;
Mat A;
PetscInitialize(&argc,&argv,(char *)0,help);
ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
ierr = DMDACreate3d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,-7,-7,-7,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,0,&da);CHKERRQ(ierr);
ierr = DMSetInitialGuess(da,ComputeInitialGuess);CHKERRQ(ierr);
ierr = DMSetFunction(da,ComputeRHS);CHKERRQ(ierr);
ierr = DMSetJacobian(da,ComputeMatrix);CHKERRQ(ierr);
ierr = KSPSetDM(ksp,da);CHKERRQ(ierr);
/* ierr = KSPSetDMActive(ksp,PETSC_FALSE);CHKERRQ(ierr);*/
ierr = DMDestroy(&da);CHKERRQ(ierr);
ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
ierr = KSPSetUp(ksp);CHKERRQ(ierr);
ierr = KSPSolve(ksp,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
ierr = KSPGetSolution(ksp,&x);CHKERRQ(ierr);
ierr = KSPGetRhs(ksp,&b);CHKERRQ(ierr);
ierr = VecDuplicate(b,&r);CHKERRQ(ierr);
ierr = KSPGetOperators(ksp,&A,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
ierr = MatMult(A,x,r);CHKERRQ(ierr);
ierr = VecAXPY(r,-1.0,b);CHKERRQ(ierr);
ierr = VecNorm(r,NORM_2,&norm);CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD,"Residual norm %G\n",norm);CHKERRQ(ierr);
ierr = OutputFunction(da,x);
ierr = VecDestroy(&r);CHKERRQ(ierr);
ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
ierr = PetscFinalize();
return 0;
#undef __FUNCT__
#define __FUNCT__ "ComputeRHS"
PetscErrorCode ComputeRHS(DM dm,Vec x,Vec b)
PetscInt mx,my,mz;
PetscScalar h;
PetscScalar ***xx,***bb;
PetscInt i,j,k,xm,ym,zm,xs,ys,zs;
PetscScalar Hx,Hy,Hz,HxHydHz,HyHzdHx,HxHzdHy;
PetscFunctionBegin;
ierr = DMDAGetInfo(dm,0,&mx,&my,&mz,0,0,0,0,0,0,0,0,0);CHKERRQ(ierr);
h = 1.0/((mx-1)*(my-1)*(mz-1));
ierr = VecSet(b,h);CHKERRQ(ierr);
if (x) {
ierr = DMDAVecGetArray(dm,x,&xx);CHKERRQ(ierr);
ierr = DMDAVecGetArray(dm,b,&bb);CHKERRQ(ierr);
Hx = 1.0 / (PetscReal)(mx-1); Hy = 1.0 / (PetscReal)(my-1); Hz = 1.0 / (PetscReal)(mz-1);
HxHydHz = Hx*Hy/Hz; HxHzdHy = Hx*Hz/Hy; HyHzdHx = Hy*Hz/Hx;
ierr = DMDAGetCorners(dm,&xs,&ys,&zs,&xm,&ym,&zm);CHKERRQ(ierr);
for (k=zs; k<zs+zm; k++){
for (j=ys; j<ys+ym; j++){
for(i=xs; i<xs+xm; i++){
if (!(i==0 || j==0 || k==0 || i==mx-1 || j==my-1 || k==mz-1)){
bb[k][j][i] -= +HxHydHz*xx[k-1][j][i] + HxHzdHy*xx[k][j-1][i] + HyHzdHx*xx[k][j][i-1] + HyHzdHx*xx[k][j][i+1] + HxHzdHy*xx[k][j+1][i] + HxHydHz*xx[k+1][j][i];
bb[k][j][i] += 2.0*(HxHydHz + HxHzdHy + HyHzdHx)*xx[k][j][i];
ierr = DMDAVecRestoreArray(dm,x,&xx);CHKERRQ(ierr);
ierr = DMDAVecRestoreArray(dm,b,&bb);CHKERRQ(ierr);
PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "ComputeInitialGuess"
PetscErrorCode ComputeInitialGuess(DM dm,Vec b)
PetscFunctionBegin;
ierr = VecSet(b,0);CHKERRQ(ierr);
#undef __FUNCT__
#define __FUNCT__ "ComputeMatrix"
PetscErrorCode ComputeMatrix(DM dm,Vec x,Mat jac,Mat B,MatStructure *stflg)
DM da = dm;
PetscInt i,j,k,mx,my,mz,xm,ym,zm,xs,ys,zs;
PetscScalar v[7],Hx,Hy,Hz,HxHydHz,HyHzdHx,HxHzdHy;
MatStencil row,col[7];
ierr = DMDAGetInfo(da,0,&mx,&my,&mz,0,0,0,0,0,0,0,0,0);CHKERRQ(ierr);
ierr = DMDAGetCorners(da,&xs,&ys,&zs,&xm,&ym,&zm);CHKERRQ(ierr);
row.i = i; row.j = j; row.k = k;
if (i==0 || j==0 || k==0 || i==mx-1 || j==my-1 || k==mz-1){
v[0] = 2.0*(HxHydHz + HxHzdHy + HyHzdHx);
ierr = MatSetValuesStencil(B,1,&row,1,&row,v,INSERT_VALUES);CHKERRQ(ierr);
} else {
v[0] = -HxHydHz;col[0].i = i; col[0].j = j; col[0].k = k-1;
v[1] = -HxHzdHy;col[1].i = i; col[1].j = j-1; col[1].k = k;
v[2] = -HyHzdHx;col[2].i = i-1; col[2].j = j; col[2].k = k;
v[3] = 2.0*(HxHydHz + HxHzdHy + HyHzdHx);col[3].i = row.i; col[3].j = row.j; col[3].k = row.k;
v[4] = -HyHzdHx;col[4].i = i+1; col[4].j = j; col[4].k = k;
v[5] = -HxHzdHy;col[5].i = i; col[5].j = j+1; col[5].k = k;
v[6] = -HxHydHz;col[6].i = i; col[6].j = j; col[6].k = k+1;
ierr = MatSetValuesStencil(B,1,&row,7,col,v,INSERT_VALUES);CHKERRQ(ierr);
ierr = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
*stflg = SAME_NONZERO_PATTERN;
return 0;
#undef __FUNCT__
#define __FUNCT__ "OutputFunction"
PetscErrorCode OutputFunction(DM da, Vec x) {
PetscScalar ***array;
PetscFunctionBegin;
ierr = DMDAVecGetArray(da, x, &array);
