[petsc-users] Debugger question
Mon Apr 2 20:45:13 CDT 2012
On Mon, Apr 2, 2012 at 8:10 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Hello
> I am trying to debug a program using the switch
> '-on_error_attach_debugger' but  the vendor/sysadmin built PETSc 3.2.00 is
> unable to start the debugger in xterm (see text below). But xterm is
> installed. What am I doing wrong?
We need the entire output since the X messages may be farther up. Also, run
it with -start_in_debugger so that they
come right at startup.
     Matt
> Btw the segfault happens during a call to MatMult but only with
> vendor/sysadmin supplied PETSc 3.2 with PGI and Intel compilers only and
> _not_ with CRAY or GNU compilers.
> I also dont get the segfault if I build PETSc 3.2-p7 myself with PGI/Intel
> compilers.
> Any ideas on how to diagnose the problem? Unfortunately I cannot seem to
> run valgrind on this particular machine.
> Thanks in advance.
> Tabrez
> stali at krakenpf1:~/meshes> which xterm
> /usr/bin/xterm
> stali at krakenpf1:~/meshes> aprun -n 1 ./defmod -f
> 2d_point_load_dyn_abc.inp -on_error_attach_debugger
> [0]PETSC ERROR: ------------------------------**
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/**
> petsc-as/documentation/faq.**html#valgrind[0]PETSC<http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC>ERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> [0]PETSC ERROR: PETSC: Attaching gdb to ./defmod of pid 32384 on display
> localhost:20.0 on machine nid10649
> Unable to start debugger in xterm: No such file or directory
> aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 0) - process 0
> _pmii_daemon(SIGCHLD): [NID 10649] [c23-3c0s6n1] [Mon Apr  2 13:06:48
> 2012] PE 0 exit signal Aborted
> Application 133198 exit codes: 134
> Application 133198 resources: utime ~1s, stime ~0s
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120402/cef9d865/attachment.htm>
