[petsc-users] Debugger question
Tabrez Ali stali at geology.wisc.edu
Mon Apr 2 20:10:11 CDT 2012
Hello
I am trying to debug a program using the switch
'-on_error_attach_debugger' but  the vendor/sysadmin built PETSc 3.2.00
is unable to start the debugger in xterm (see text below). But xterm is
installed. What am I doing wrong?
Btw the segfault happens during a call to MatMult but only with
vendor/sysadmin supplied PETSc 3.2 with PGI and Intel compilers only and
_not_ with CRAY or GNU compilers.
I also dont get the segfault if I build PETSc 3.2-p7 myself with
PGI/Intel compilers.
Any ideas on how to diagnose the problem? Unfortunately I cannot seem to
run valgrind on this particular machine.
Thanks in advance.
Tabrez
stali at krakenpf1:~/meshes> which xterm
/usr/bin/xterm
stali at krakenpf1:~/meshes> aprun -n 1 ./defmod -f
2d_point_load_dyn_abc.inp -on_error_attach_debugger
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR: PETSC: Attaching gdb to ./defmod of pid 32384 on display
localhost:20.0 on machine nid10649
Unable to start debugger in xterm: No such file or directory
aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 0) - process 0
_pmii_daemon(SIGCHLD): [NID 10649] [c23-3c0s6n1] [Mon Apr  2 13:06:48
2012] PE 0 exit signal Aborted
Application 133198 exit codes: 134
Application 133198 resources: utime ~1s, stime ~0s
