[petsc-users] Problem with mpiexec
Jed Brown
jedbrown at mcs.anl.gov
Mon Sep 26 23:08:07 CDT 2011
On Mon, Sep 26, 2011 at 23:04, Konstantinos Kontzialis <
ckontzialis at lycos.com> wrote:
> Dear all,
> I use Fedora 15 and I needed to make a new install of the system. However,
> when I installed petsc mpiexec did not work. Fedora 15 uses now mpich2-1.4.1
> which uses hydra as the default process manager. But nothing is working.
As always, what are the complete symptoms? What are you trying to do and
what happens?
> Any suggestions about what should I check and what to do?
The most common problem is that you have more than one mpiexec and that a
different MPI is used for compilation.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110926/e7c966e7/attachment.htm>
