[petsc-users] Problem with mpiexec
Sean Farley sean at mcs.anl.gov
Mon Sep 26 23:07:26 CDT 2011
> I use Fedora 15 and I needed to make a new install of the system. However,
> when I installed petsc mpiexec did not work. Fedora 15 uses now mpich2-1.4.1
> which uses hydra as the default process manager. But nothing is working. Any
> suggestions about what should I check and what to do?
I use mpich2-1.4.1 on all my systems (mac and linux) and have no problem
with hydra. What went wrong? A configure error? A make error? Or a runtime
error? I think regardless of which error it is, you should send your
configure.log (and make.log if it got that far) to petsc-maint.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110926/14f871bb/attachment.htm>
