[petsc-users] Problem with petsc-dev update
Alan Wei zhenglun.wei at gmail.com
Fri Sep 23 16:45:52 CDT 2011
Thanks, Matt,
*Something is wrong with your repo. Pull petsc-dev again and look at
snesregi.c*
So, I did:
cd petsc-dev
hg pull -u
and reconfigure and make.
still have the same problem. >_<
Alan
On Fri, Sep 23, 2011 at 4:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 23, 2011 at 2:33 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
>> Dear folks,
>>     I just update petsc-dev following
>> PETSc can now be configured in the usual way, specified on the Installation
>> page<http://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html>.
>> To update your copy of petsc-dev
>>    - cd petsc-dev
>>    - hg pull -u
>>    - cd config/BuildSystem
>>    - hg pull -u
>> Once updated, you will usually want to rebuild completely
>>    - cd petsc-dev
>>    - ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>    - make
>>    however, after I have done that, I test a example which can be run just
>> before I did the update and failed witha error message:
>> /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib/libpetsc.a(snesregi.o):
>> In function `SNESRegisterAll':
>> /home/zlwei/soft/mercurial/petsc-dev/src/snes/interface/snesregi.c:63:
>> undefined reference to `SNESCreate_FAS'
> snesregi.c
>    Matt
>>    BTW, the configure.log and make.log are attached.
>> thanks in advance,
>> Alan
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110923/47b47b31/attachment.htm>
