[petsc-users] Problem with petsc-dev update
Matthew Knepley
knepley at gmail.com
Fri Sep 23 16:39:57 CDT 2011
On Fri, Sep 23, 2011 at 2:33 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
> Dear folks,
> I just update petsc-dev following
> PETSc can now be configured in the usual way, specified on the Installation
> page<http://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html>.
> To update your copy of petsc-dev
> - cd petsc-dev
> - hg pull -u
> - cd config/BuildSystem
> - hg pull -u
> Once updated, you will usually want to rebuild completely
> - cd petsc-dev
> - ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> - make
> however, after I have done that, I test a example which can be run just
> before I did the update and failed witha error message:
> /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib/libpetsc.a(snesregi.o):
> In function `SNESRegisterAll':
> /home/zlwei/soft/mercurial/petsc-dev/src/snes/interface/snesregi.c:63:
> undefined reference to `SNESCreate_FAS'
Something is wrong with your repo. Pull petsc-dev again and look at
snesregi.c
Matt
> BTW, the configure.log and make.log are attached.
> thanks in advance,
> Alan
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110923/4a39b7a6/attachment.htm>
