[petsc-users] Does float128 helps ksp solver convergence
Gong Ding gdiso at ustc.edu
Sun Sep 18 11:09:42 CDT 2011
Thanks, the synopsys TCAD product announced they use 128 bit float for numerically stable reason.
I will try some more robust methods first.
float128 seems not compatible with most external direct solvers.
On Sun, Sep 18, 2011 at 17:07, Gong Ding<gdiso at ustc.edu> wrote:
Do you mean GMRES-like method will bebenefited from float 128?
It could be, especially if you use a finite difference Jacobian. If you suspect precision issues, you can try more robust orthogonalization -ksp_gmres_modifiedgramschmidt or -ksp_type gcr, or you can just try using float128.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110919/1e61d79b/attachment.htm>
