[petsc-users] Does float128 helps ksp solver convergence
Jed Brown
jedbrown at mcs.anl.gov
Sun Sep 18 10:24:10 CDT 2011
On Sun, Sep 18, 2011 at 17:07, Gong Ding <gdiso at ustc.edu> wrote:
> Do you mean GMRES-like method will be benefited from float 128?
It could be, especially if you use a finite difference Jacobian. If you
suspect precision issues, you can try more robust orthogonalization
-ksp_gmres_modifiedgramschmidt or -ksp_type gcr, or you can just try using
float128.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110918/fbfa717f/attachment.htm>
