[petsc-users] viewers and nohup (unrelated questions)
Gianluca Meneghello gianmail at gmail.com
Fri Sep 16 11:51:54 CDT 2011
No particular reason except the fact that I don't know them!
I will have a look at how they work. Thanks for the suggestion.
gianluca
On 16 September 2011 18:31, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Sep 16, 2011 at 18:09, Gianluca Meneghello <gianmail at gmail.com>
> wrote:
>> If it can be useful, nohup is not respected only when the job is
>> submitted using an ssh connection (and the ssh connection is closed).
> Sounds like a problem with nohup/ssh. Isn't the whole point of nohup to
> prevent sending HUP to the application? Is the shell the same (interactive
> and login) via the terminal and via ssh?
> Is there a reason you don't want to run the job in a screen or tmux session?
> (I have always found that preferable to using nohup.)
"[Je pense que] l'homme est un monde qui vaut des fois les mondes et
que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
l'Anonymat" -- Non omnibus, sed mihi et tibi
Amedeo Modigliani
