[petsc-users] viewers and nohup (unrelated questions)
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Sep 16 11:31:11 CDT 2011
On Fri, Sep 16, 2011 at 18:09, Gianluca Meneghello <gianmail at gmail.com>wrote:
> If it can be useful, nohup is not respected only when the job is
> submitted using an ssh connection (and the ssh connection is closed).
Sounds like a problem with nohup/ssh. Isn't the whole point of nohup to
prevent sending HUP to the application? Is the shell the same (interactive
and login) via the terminal and via ssh?
Is there a reason you don't want to run the job in a screen or tmux session?
(I have always found that preferable to using nohup.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110916/a6fd6cfd/attachment.htm>
