[petsc-users] viewers and nohup (unrelated questions)
Fri Sep 16 08:09:32 CDT 2011
On Fri, Sep 16, 2011 at 7:17 AM, Gianluca Meneghello <gianmail at gmail.com>wrote:
> Hi,
> I would like to ask you 2 unrelated questions.
> #_1 The first one concerns PETSc viewer. In my code I'm writing
> outputs with PETSC_VIEWER_ASCII_VTK, more precisely
>    PetscViewer viewer;
>    PetscViewerASCIIOpen(PETSC_COMM_SELF,filename.c_str(),&viewer);
>    PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_VTK);
>    DMView(dau,viewer);
>    VecView(foou,viewer);
>    VecView(foop,viewer);
>    PetscViewerDestroy(&viewer);
> where foou and foop (velocity and pressure respectively) are vectors
> extracted from the vector containing the full solution of my problem.
> The VTK so obtained nicely contains a vector field — from foou — and a
> scalar field — foop — and can be read by Paraview.
> Nonetheless, I guess writing (and reading from Paraview) ASCII files
> is not the best choice. Are there better possibilities in PETSc? Is
> there a PETSC_VIEWER_BINARY_VTK or equivalent?
We are working on it but it is not yet ready.
> #_2 The second is about the nohup command. If I run my code with
> "nohup ./main <opts> &" and then exit the console, the program dies as
> if there was no nohup command in front of it. The same is true for
> some examples I've tested from the PETSc library. I guess this is
> related to the machine I'm using more than to the library but... has
> anyone of you already experienced a similar issue? Any advice is
> welcome and please let me know if you need any information that can
> help.
Dos your program die from a HUP signal or another one?
     Matt
> Thanks
> Gianluca
> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
> l'Anonymat" -- Non omnibus, sed mihi et tibi
> Amedeo Modigliani
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110916/f059c3fa/attachment.htm>
